Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
MacBook Pro 15" Unibody (Late 2008-Late 2011) LCD Panel
  • MacBook Pro 15" Unibody (Late 2008-Late 2011) LCD Panel
84,99 USD
84,99 USD
Ti invieremo un messaggio quando il prodotto sarà nuovamente disponibile.
Kit per Nintendo Switch
A quick fix to get back in the game
Shop Switch Kits
Shop Switch Kits
Dettagli Prodotto
Descrizione
Descrizione
Replacement display panel for 15.4" Unibody displays. Compatible with all 15" Unibody MacBook Pros. 15.4” screen.
Compatibilità
Compatibilità
  • MacBook Pro 15" Unibody A1286 Late 2008 to Late 2011
Specifiche
Specifiche
Part #:
LP154WP3-TLA3, LP154WP4-TLA1
Size:
15.4"
Resolution:
Standard: 1440x900
High: 1680x1050
Compatibilità
MacBook Pro 15" Unibody 2.53 GHz Mid 2009
MacBook Pro 15" Unibody Early 2011
2 GHz
2.2 GHz
2.3 GHz
MacBook Pro 15" Unibody Late 2008 & Early 2009
2.4 GHz
2.53 GHz
2.66 GHz
2.8 GHz
2.93 GHz
MacBook Pro 15" Unibody Late 2011
2.2 GHz
2.4 GHz
2.5 GHz
MacBook Pro 15" Unibody Mid 2009
2.66 GHz
2.8 GHz
3.06 GHz
MacBook Pro 15" Unibody Mid 2010
2.4 GHz
2.53 GHz
2.66 GHz
2.8 GHz
Visualizza 3 altri dispositivi
Storie di Riparazione
Avatar utente
patrash's Story Photo #229687
patrash's Story Photo #229688
Il Mio Problema
LCD on MacBookPro was damaged and didn´t work properly
La Mia Riparazione
Like a charm!
It was a bit hard no exactly know how much heating had to be done to ensure that display glam could be removed from adhesive edge around the display. I think I accidently heated it too much and a huall area of the glam became a bi . . .
Avatar utente
Il Mio Problema
My lcd was bad
La Mia Riparazione
As many others have said, getting the glass off was real tough, I found that when I wasn't having success in one corner, I tried a lower corner and it worked much better. From there I just pried all the way around, making sure to heat a bit as I went.
Il Mio Consiglio
I bought my led from Ifixit and the . . .
Avatar utente
Il Mio Problema
I always try to fix things myself, and my wifes laptop screen was not going to be an exception.
La Mia Riparazione
Easy! Simple! Step by step instructions that even a monkey can learn to follow. This was my first time ever working on electronics, so it was a bit intimidating at first, but very easy. The parts i ordered . . .
Avatar utente
Il Mio Problema
Back of aluminum had something fall on it and dented right into the lcd , and broke it.
La Mia Riparazione
Very well , easy followed instructions did it in just under an hour for disassembling . Part arrived the next day put it in and reassembled in less time .
I had to drill out some stripped screws .. No big deal . . . .
Avatar utente
Il Mio Problema
Il mio schermo LCD é morto ,fuori garanzia ovviamente costo riparazione 600 euro e più. Dopo aver messo del disossidante per contatti sul connettore dello schermo ha ricominciato a funzionare , peccato che abbia rovinato lo schermo
La Mia Riparazione
Riparazione avvenuta con successo, a parte gli insetti dentro lo sc . . .
Avatar utente
Il Mio Problema
Screen was smashed so I had to fix it
La Mia Riparazione
This was not easy, but definitely worth the work. The instructions on this website are superb
Il Mio Consiglio
Make sure to keep track of which screws go where!
Avatar utente
Il Mio Problema
Lcd was broken, its cheaper do it by yourself
La Mia Riparazione
LCD was replaced flawlessly... the front glass didnt had the same fate.
Il Mio Consiglio
remove the front glass is very tricky, better consider have a spare front glass handy
Avatar utente
Il Mio Problema
Broken LCD w/ verticle bands of solid white/black.
La Mia Riparazione
Reasonably well. Used a hair dryer instead of a heat gun. Had a lot of trouble getting LVDS cable (also replaced) to stay in the lcd when putting everything back together.
Il Mio Consiglio
My LCD panel has about 50 stuck red pixels all in a clump in the lower left cor . . .
Avatar utente
Il Mio Problema
My mac took a bit of a tumble and the bottom quarter of the screen was distorted to just lines. Took it into to an Apple store to make sure it was the right problem and see if it would at least be around the same price as fixing it myself, but ~$500 was a little pricey for me.
La Mia Riparazione
I only had two issues c . . .
Avatar utente
Il Mio Problema
The late-2008 Macbook Pro 15" - after a lightning discharged quite nearby the screen acquired a bad habit of turning white washed out. Could be a coincidence or just a factor promoting a defect.
The washout could be remedied by a little pinching of the screen - so it was just a matter of time the g . . .
Mostra di più
