Aggiusta la tua roba
Diritto alla Riparazione
Store
MacBook Pro 15" Unibody (Early 2011-Mid 2012) Replacement Battery
  • MacBook Pro 15" Unibody (Early 2011-Mid 2012) Replacement Battery / New / Fix Kit
  • MacBook Pro 15" Unibody (Early 2011-Mid 2012) Replacement Battery / New / Part Only
  • 360°
360
94,99 USD
94,99 USD
Dettagli Prodotto
Descrizione
Descrizione
This MacBook Pro 15" Unibody (Early 2011-Mid 2012) replacement battery is what you need to bring your dead laptop back to life!
  • 100% factory tested.
  • Tested and guaranteed to have no cycles on the cell and to have a capacity greater than 6730 mAh.
  • Spot tested by iFixit staff in San Luis Obispo, CA to ensure consistency of quality and capacity.
  • Assembled using a high quality chipset from Texas Instruments.
Battery degradation is an inevitable part of your laptop’s lifespan, extend it with this replacement battery compatible with Early 2011 to Mid 2012 MacBook Pro 15" Unibody. Factory-installed MacBook Pro batteries are rated to last 1,000 cycles. If your laptop won't turn on, turns off suddenly, has a "service battery" warning, or simply won't hold a charge, this replacement battery may be what you need to fix it. Our aftermarket replacement batteries lead the industry in quality and reliability, so you know you're getting the best money can buy.
Contenuto del kit
Contenuto del kit
Compatibilità
Compatibilità
  • MacBook Pro 15" Unibody A1286 Early 2011 to Mid 2012
Specifiche
Specifiche
Manufacturer:
Aftermarket
Part #:
661-5844
Model #:
A1382
Watt Hours:
77.5 Wh
Voltage:
10.95 V
Milliamp Hours:
7080 mAh
Compatibilità
MacBook Pro 15" Unibody Early 2011
A1286 (EMC 2353-1) 2 GHz
A1286 (EMC 2353-1) 2.2 GHz
A1286 (EMC 2353-1) 2.3 GHz
MacBook Pro 15" Unibody Late 2011
A1286 (EMC 2563) 2.2 GHz
A1286 (EMC 2563) 2.4 GHz
A1286 (EMC 2563) 2.5 GHz
MacBook Pro 15" Unibody Mid 2012
A1286 (EMC 2556) 2.3 GHz
A1286 (EMC 2556) 2.6 GHz
A1286 (EMC 2556) 2.7 GHz
Recensioni dei clienti
