Aggiusta la tua roba
Diritto alla Riparazione
Store
MacBook Pro 15" Unibody (Early 2011-Late 2011) Display Assembly
  • MacBook Pro 15" Unibody (Early 2011-Late 2011) Display Assembly
149,99 USD
149,99 USD
Dettagli Prodotto
Descrizione
Descrizione
This Early 2011-Late 2011 MacBook Pro 15" Unibody replacement display includes all of the small parts preinstalled in the assembly, saving time and increasing the quality of your repair.
Replace a broken front glass or malfunctioning LCD display on your laptop. This screen assembly will renew the appearance of your front panel and eliminate the flickering on an aging display.
L'insieme delle parti comprende
  • 15.4" LCD screen
  • Display Cover
  • Bezel
  • FaceTime HD Camera
  • Clutch Hinges
  • Wi-Fi Antenna
  • Camera
  • Display Data Cables
Compatibilità
Compatibilità
  • MacBook Pro 15" Unibody A1286 Early 2011 to Late 2011
Specifiche
Specifiche
Part #:
661-5847
Size:
15.4"
Compatibilità
MacBook Pro 15" Unibody Early 2011
A1286 (EMC 2353-1) 2 GHz
A1286 (EMC 2353-1) 2.2 GHz
A1286 (EMC 2353-1) 2.3 GHz
MacBook Pro 15" Unibody Late 2011
A1286 (EMC 2563) 2.2 GHz
A1286 (EMC 2563) 2.4 GHz
A1286 (EMC 2563) 2.5 GHz
Storie di Riparazione
Avatar utente
Il Mio Problema
Bought a macbook pro as a refurbished device with a Matt screen, and the colors where washed out.
La Mia Riparazione
Pretty easy
Il Mio Consiglio
When putting the new screen in the alignment for the hinges are a little bit tricky just some patience and you'll be golden
Avatar utente
Il Mio Problema
Screen glass, display and top cover damaged due hard object dropping onto my wife's computer when in closed position.
La Mia Riparazione
Repair went OK until having to remove cable display data cable retainer from the upper case. The retaining screw could not be removed however hard I tried - the result being that th . . .
