Aggiusta la tua roba
Diritto alla Riparazione
Store
Parts Mac MacBook Pro MacBook Pro 15" MacBook Pro 15" (Non-Unibody) Logic Boards
Store
Grab a toolkit for your MacBook Pro 15" (Non-Unibody) model and fix your broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
Non sai qual è il tuo modello? ID del tuo Mac
MacBook Pro 15" (Model A1226) 2.4 GHz Logic Board
Replace a broken or damaged 2.4 GHz logic board in your Model A1226 MacBook Pro 15" with this part.
274,99 USD
MacBook Pro 15" (Model A1260) 2.4 GHz Logic Board
2.4 GHz Core 2 Duo Penryn Motherboard / Ports: DVI Video Out, 1000BaseT Ethernet, Firewire 800, Firewire 400, USB 2.0 (high power)
299,99 USD
MacBook Pro 15" (Model A1260) 2.5 GHz Logic Board
2.5 GHz Core 2 Duo Penryn Motherboard / Ports: DVI Video Out, 1000BaseT Ethernet, Firewire 800, Firewire 400, USB 2.0 (high power)
299,99 USD
MacBook Pro 15" (Model A1226) 2.6 GHz Logic Board
2.6 GHz Core 2 Duo Santa Rosa Motherboard / Ports: DVI Video Out, 1000BaseT Ethernet, Firewire 800, Firewire 400, USB 2.0
349,99 USD
MacBook Pro 15" (Model A1150) 2.16 GHz Logic Board
2.16 GHz Motherboard / Ports: DVI Video Out, 1000BaseT Ethernet, Firewire 400, USB 2.0
249,99 USD
MacBook Pro 15" (Model A1150) 2 GHz Logic Board
2 GHz Motherboard / Ports: DVI Video Out, 1000BaseT Ethernet, Firewire 400, USB 2.0
124,99 USD
MacBook Pro 15" (Model A1150) 1.83 GHz Logic Board
249,99 USD
MacBook Pro 15" (Model A1211) 2.16 GHz Logic Board
2.16 GHz Core 2 Duo Motherboard / Ports: DVI Video Out, 1000BaseT Ethernet, Firewire 800, Firewire 400, USB 2.0
249,99 USD
MacBook Pro 15" (Model A1211) 2.33 GHz Logic Board
2.33 GHz Core 2 Duo Motherboard / Ports: DVI Video Out, 1000BaseT Ethernet, Firewire 800, Firewire 400, USB 2.0
149,99 USD
MacBook Pro 15" (Model A1226) 2.2 GHz Logic Board
2.2 GHz Core 2 Duo Motherboard / Ports: DVI Video Out, 1000BaseT Ethernet, Firewire 800, Firewire 400, USB 2.0
249,99 USD
Visualizzazione prodotti 1 - 10 di 10
Informazioni Dispositivo
The MacBook Pro 15" replaced the Aluminum 15" and features Intel support and an integrated iSight camera.
All MacBook Pro 15" Non-Unibody models use PC2-5300 RAM. Two RAM slots means an easy memory upgrade! If storage is an issue, any 9.5mm SATA hard drive will expand your boundaries.
Heat has always been an issue for MacBook Pros. It's possible that a bad thermal sensor or fan will prevent the machine from booting.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 15" Non-Unibody repair guides for step-by-step instructions on how to make the fix.
