MacBook Pro 15" Unibody Mid 2012 Optical Drives
Grab a toolkit for your MacBook Pro 15" Unibody Mid 2012 model and fix your broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
Parti che funzionano con MacBook Pro 15" Unibody Mid 2012:
Unibody Laptop Dual Drive
Increase the storage space in your laptop by replacing the optical drive with a second hard drive or SSD.
MacBook Pro 15" Unibody (Mid 2009-Mid 2012) 8x SATA SuperDrive (Used)
Replace a broken or damaged SuperDrive for your Mid 2009 to Mid 2012 MacBook Pro 15" Unibody with this part. This part includes the metal mounting bracket but does not in...
SATA Optical Drive USB Cable
Connect an optical drive to your computer via USB with this part.
MacBook Pro 15" Unibody (Mid 2009-Mid 2012) SATA SuperDrive Cable
Replace a damaged or missing cable connecting the SuperDrive to the logic board.
Unibody (Post-Early 2009) 8x SATA SuperDrive
Replace a broken or damaged SuperDrive for your Post-Early 2009 MacBook Unibody with this part. This part does not include the metal mounting bracket and orange ribbon ca...
Informazioni Dispositivo
The Mid 2012 version of MacBook Pro 15" Unibody is virtually identical to the Late 2011 model with a CPU and graphics upgrade. It features an Ivy Bridge quad core Core i7 processor with PC3-10600 RAM. In addition to the Thunderbolt port and SDXC card slot it now features two USB 3 ports.
The most common repairs with Mid 2012 model MacBook Pro 15" Unibody laptops are replacing a dead battery, replacing a malfunctioning left or right fan, and upgrading the hard drive or RAM. The MacBook Pro 15" Unibody (Mid 2012) Memory Maxxer RAM Upgrade Kit includes all the parts and tools you need to upgrade to 16 GB of RAM.
The Mid 2012 model MacBook Pro 15" Unibody requires a Tri-point Y0 Screwdriver to remove the battery. Our battery repair kits include all the needed tools.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 15" Unibody Mid 2012 repair guides for step-by-step instructions on how to make the fix.
