Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
Parts Mac MacBook Pro MacBook Pro 13" Drivers and Wrenches
Store
Grab a toolkit for your MacBook Pro 13" model and fix your broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
Non sai qual è il tuo modello? ID del tuo Mac
MacBook Pro 13" Unibody (Mid 2009-Mid 2012) Replacement Battery / Fix Kit
Replace a 5800 mAh battery compatible with MacBook Pro 13" Unibody (Mid 2009 to Mid 2012). 63.5 Watt Hours (Wh), 10.95 Volts (V).
Da 94,99 USD
MacBook Pro Retina (A1425, A1502, and A1398) Plastic Feet / Part Only
Replace missing or damaged black plastic feet on your laptop's lower case.
Da 4,99 USD
MacBook and MacBook Pro Unibody Plastic Feet / Part Only
Replace the black plastic feet on the lower case of your Unibody MacBook or MacBook Pro.
Da 4,99 USD
MacBook Pro 13" Retina (Early 2015) Battery / New / Fix Kit
Replace a 6560 mAh battery compatible with MacBook Pro 13" Retina (Early 2015). 74.9 Watt Hours (Wh), 11.42 Volts (V).
Da 99,99 USD
Arctic Silver Thermal Paste
Forms a continuous, heat conductive layer between a processor and its heat sink. A new layer of thermal paste keeps your processor from overheating. 3.5 grams
8,99 USD
MacBook Pro 13" Retina (Late 2013-Mid 2014) Battery / New / Fix Kit
Replace a 6330 mAh battery compatible with MacBook Pro 13" Retina Late 2013 to Mid 2014 A1502 model laptops. 71.8 Watt Hours (Wh). 11.34 Volts (V).
Da 99,99 USD
MacBook and MacBook Pro (Non-Retina) SSD Upgrade Bundle / Crucial 250 GB
Upgrade the storage and improve boot time and read/write speed in your MacBook and MacBook Pro (Non-Retina) with this SSD upgrade bundle.
Da 89,99 USD
Arctic Silver ArctiClean
Two part cleaner dissolves old thermal paste on heat sinks and processors. One 30 ml bottle of thermal material remover and one 30 ml bottle of thermal surface purifier.
9,99 USD
MacBook Pro Unibody Lower Case Screw Set / Part Only
Replace a stripped or missing screw securing the lower case of most Unibody model MacBook Pro laptops. The excluded models are the Late 2008 and Early 2009 15" MacBook Pr...
Da 9,99 USD
MacBook Pro 13" Retina (Early 2015) Trackpad Cable
Replace the flex cable that connects the trackpad to the logic board compatible with the Early 2015 model A1502 MacBook Pro 13" Retina laptop. Part #821-00184.
9,99 USD
Visualizzazione prodotti 1 - 10 di 238
Informazioni Dispositivo
Catering to the working professional, the MacBook Pro 13" is aptly named. With powerful processor and graphics capabilities, these Apple machines are great for either the professional or aspiring creative genius.
Select your version above for parts and assistance!
