Aggiusta la tua roba
Diritto alla Riparazione
Store
MacBook Core Duo/Santa Rosa/Penryn LCD Mounts
  • MacBook Core Duo/Santa Rosa/Penryn LCD Mounts
7,99 USD
7,99 USD
Dettagli Prodotto
Descrizione
Descrizione
LCD hanging on by a thread?
Lock it down with some LCD mounts! Includes LCD mounts and airport antenna cables.
This part works with model A1181 MacBooks with 2 antenna connectors. If your MacBook has 3 antenna connectors you need the Core 2 Duo hinge mounts.
Compatibilità
Compatibilità
  • 1.83 or 2 GHz Core Duo MacBooks
  • 2.0 (Santa Rosa) or 2.2 GHz Core 2 Duo MacBooks
  • 2.1 or 2.4 GHz Core 2 Duo MacBooks
  • 2.0 GHz (Early 2009) Core 2 Duo MacBooks
  • 2.13 GHz (Mid 2009) Core 2 Duo MacBooks
Compatibilità
MacBook Core 2 Duo
A1181 (EMC 2121) 2 GHz (Santa Rosa)
A1181 (EMC 2200) 2.2 GHz (Santa Rosa)
A1181 (EMC 2242) 2.1 GHz (Penryn)
A1181 (EMC 2242) 2.4 GHz (Penryn)
A1181 (EMC 2300) 2 GHz (Early 2009)
A1181 (EMC 2330) 2.13 GHz (Mid 2009)
MacBook Core Duo
A1181 (EMC 2092) 1.83 GHz
A1181 (EMC 2092) 2 GHz
Storie di Riparazione
Avatar utente
Il Mio Problema
WIFI antenna wire was broken where it passes through the hinge of the display.
La Mia Riparazione
The online guide was helpful - take the time to go slow and follow each step.
Il Mio Consiglio
Set aside enough time to do the repair right - keep track of where the screws from each step go so you don't get them mixed up later.
Avatar utente
Il Mio Problema
My airport would only work if the computer did not move after startup. If moved the airport would turn off and could not be turned back on without restarting. After researching the problem I deduced that it was probable that the antenna wires had been pinched/worn from the screen opening and closing . . .
