Aggiusta la tua roba
Diritto alla Riparazione
Store
Parts Mac MacBook MacBook Core 2 Duo Logic Boards
Store
Grab a toolkit for your MacBook Core 2 Duo model and bring your laptop back to life!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
Non sai qual è il tuo modello? ID del tuo Mac
MacBook Core 2 Duo 2.4 GHz Logic Board
Replace a 2.4 GHz logic board (motherboard) compatible with the MacBook Core 2 Duo. Fix processing issues like unexpected shutdowns, reboots or water damage. Included Por...
189,99 USD
MacBook (Early 2009) 2 GHz Logic Board
Replace a 2 GHz logic board (motherboard) compatible with the Early 2009 MacBook. Ports: Mini-DVI Port, 1000BaseT Ethernet, Firewire 400, 2 USB 2.0, Audio in, Audio out. ...
299,99 USD
MacBook (Mid 2009) 2.13 GHz Logic Board
Replace a 2.13 GHz logic board (motherboard) compatible with the Mid 2009 MacBook. Fix processing issues like unexpected shutdowns, reboots or water damage. Ports: Mini-D...
Da 224,99 USD
MacBook Core 2 Duo 2 GHz (non-Energy Star) Logic Board
Replace a 2 GHz logic board (motherboard) compatible with the MacBook Core 2 Duo model laptop. Fix processing issues like unexpected shutdowns, reboots or water damage. P...
129,99 USD
MacBook Core 2 Duo 1.83 GHz Logic Board / White
Replace a 1.83 GHz logic board (motherboard) compatible with the MacBook Core 2 Duo model laptop. Fix processing issues like unexpected shutdowns, reboots or water damage...
99,99 USD
MacBook Core 2 Duo 2 GHz (Energy Star) Logic Board
Replace a 2 GHz Energy Star logic board (motherboard) compatible with the MacBook Core 2 Duo model laptop. Fix processing issues like unexpected shutdowns, reboots or wat...
149,99 USD
MacBook Core 2 Duo 2.16 GHz (non-Energy Star) Logic Board
Replace a 2.16 GHz logic board (motherboard) compatible with the MacBook Core 2 Duo model laptop. Fix processing issues like unexpected shutdowns, reboots or water damage...
129,99 USD
MacBook 2 GHz Santa Rosa Logic Board
Replace a 2 GHz Santa Rosa logic board (motherboard) compatible with the MacBook. Fix processing issues like unexpected shutdowns, reboots or water damage. Ports: Mini DV...
169,99 USD
MacBook Core 2 Duo 2.16 GHz (Energy Star) Logic Board
Replace a 2.16 GHz logic board (motherboard) compatible with the MacBook Core 2 Duo model laptop. Included Ports: Mini DVI Video Out, 1000BaseT Ethernet, Firewire 400, 2 ...
149,99 USD
MacBook Core 2 Duo 2.1 GHz Logic Board
Replace a 2.1 GHz logic board (motherboard) compatible with the MacBook Core 2 Duo model laptop. Fix processing issues like unexpected shutdowns, reboots or water damage....
74,99 USD
Visualizzazione prodotti 1 - 10 di 11
Informazioni Dispositivo
The Core 2 Duo MacBooks feature beefier processors, thanks to the Core 2 Duo chipset. The Santa Rosa versions feature faster bus speeds and a graphics processor upgrade. A comprehensive change to a new type of logic board connector makes this version largely incompatible with prior MacBook versions. Penryn versions feature faster processor speeds. For the Early and Mid 2009 models, Apple introduced optical drives with SATA interface. Bluetooth has also been updated to version 2.1.
The 500 GB 7200 RPM SATA hard drive will max out your storage.
Check out our MacBook troubleshooting page for help in diagnosing your machine!
Select your model above or browse all compatible parts to find what you need to fix your laptop!
