MacBook Air 11" (Mid 2011-Early 2015) Replacement Battery
  • MacBook Air 11" (Mid 2011-Early 2015) Replacement Battery / Fix Kit
  • MacBook Air 11" (Mid 2011-Early 2015) Replacement Battery / Part Only
  • 360°
360
74,99 US$
74,99 US$
Ti invieremo un messaggio quando il prodotto sarà nuovamente disponibile.
Dettagli Prodotto
Descrizione
Descrizione
This MacBook Air 11" (Mid 2011 to Early 2015) Replacement Battery Fix Kit is everything you need to bring your laptop back back to life. Our aftermarket replacement batteries lead the industry in quality and reliability—each is tested and guaranteed to have a capacity greater than 4850 mAh. This fix kit comes with a brand new battery and all the tools you need to make the fix.
Contenuto del kit
Contenuto del kit
Nota
Lithium ion battery shipping regulations limit the shipping methods for orders containing batteries. Domestic orders may only be shipped via Standard shipping. iFixit is not able to ship batteries internationally or outside the contiguous US at this time. iFixit Customer Support will contact you if your order needs to be modified after it is placed.
A small percentage of users have experienced issues with aftermarket (non-Apple) batteries failing to be recognized properly in devices running Mac OS X El Capitan (10.11.x) or Sierra (10.12.x). If your system does not operate properly with our replacement battery, it can be returned for a full refund.
Attenzione
Lithium-ion batteries pose a fire hazard if they swell due to age or defect. Learn more about safe handling and proper disposal of all batteries.
Compatibilità
MacBook Air 11" Early 2014
1.4 GHz
1.7 GHz
MacBook Air 11" Early 2015
1.6 GHz
2.2 GHz
MacBook Air 11" Mid 2011
1.6 GHz
1.8 GHz
MacBook Air 11" Mid 2012
1.7 GHz
2.0 GHz
MacBook Air 11" Mid 2013
1.3 GHz
1.7 GHz
Visualizza 2 altri dispositivi
Storie di Riparazione
Adalsteinn Hjalmarsson's Story Photo #910862
Adalsteinn Hjalmarsson's Story Photo #910864
Adalsteinn Hjalmarsson's Story Photo #910865
Il Mio Problema
Swollen Battery. Computer looked like it was going to explode.
La Mia Riparazione
Easy with the iFixit Guide and iFixit Tools
Il Mio Consiglio
Use good lighting, right tools, be uninterrupted and have time.
Robert's Story Photo #1371898
Il Mio Problema
My aged MBA was losing battery power very quickly.
La Mia Riparazione
I was able to easily order the correct materials using their links in the directions. The repair went exactly as it showed in the directions. It was extremely simple and straightforward using their descriptions and pictures. The difficulty and time . . .
Steven  OConnor's Story Photo #1140101
Il Mio Problema
Replaced the battery easily.
La Mia Riparazione
Without a hitch—just have the right sized tools to remove screws from case and battery. If not you may run into a problem.
Il Mio Consiglio
Proper tools take pictures before you disassemble. Keep parts organized while disassembled for easier reassembly. Take note of where longer screws g . . .
Il Mio Problema
Original battery would not hold charge.
La Mia Riparazione
The easiest repair (with the correct tools).
Il Mio Consiglio
Have some canned air available to blow out dust bunnies. Store screws in safe place before you starts blowing out any accumulated dust.
Il Mio Problema
Dead battery
La Mia Riparazione
I followed the instructions on the video and it went well without a hitch. First time opening up a Mac laptop. I appreciated how you gave suggestions on which tools to order to do the job right.
Il Mio Consiglio
I appreciated how you gave suggestions on which tools to order to do the job right. My advi . . .
Il Mio Problema
My battery is getting old and i needed to replace it
La Mia Riparazione
Very easy as i have the fixit utility tool kit i was able to have the right tools at the right time
Il Mio Consiglio
just follow the steps!!!
Il Mio Problema
Spilled a little fluid onto macbook
La Mia Riparazione
lt worked while plugged in. Took it to try the Apple genius bar. They said I had fluid all over the components and that it would cost $750 plus tax to fix. I then took it to my friend from work who knows a lot about computers. He ran diagnostics and the system told . . .
Il Mio Problema
The battery on the Macbook Air wasn't last longer than 10 minutes. The battery icon was also indicating to replace the battery.
La Mia Riparazione
Very quick and easy
Il Mio Consiglio
This is indicated in the repair guide but the Macbook air does not use torx screw driver for the outside casing as well as for the battery
Il Mio Problema
Batteries were broken due to age not loading cycles
La Mia Riparazione
As the 2011 Macbook Airs are not filled with glue (as the newer models) it just took the 2 right screw drivers and 15 minutes per device (a 11 and a 13 inch MB Air).
Il Mio Consiglio
The ifixit guide gives you the perfect security and support that you can perform th . . .
Il Mio Problema
The battery had swollen.
La Mia Riparazione
Very simple repair, just make sure you have a container for the little screws (which are of different lengths).
Il Mio Consiglio
I suggest that as you take them out, you stick them to a piece of tape—that way they are easy to keep in order and not to lose.
Mostra di più
