Dettagli Prodotto
Descrizione
This MacBook Air 11" (Mid 2011-Early 2015) replacement battery is what you need to bring your dead laptop back to life!
- 100% factory tested.
- Tested and guaranteed to have no cycles on the cell and to have a capacity greater than 4850 mAh.
- Spot tested by iFixit staff in San Luis Obispo, CA to ensure consistency of quality and capacity.
- Assembled using a high quality chipset from Texas Instruments.
Battery degradation is an inevitable part of your laptop's lifespan, extend it with this new replacement battery compatible with Mid 2011 to Early 2015 model 11" MacBook Airs. Factory-installed MacBook Air batteries are rated to last 1,000 cycles. If your laptop won't turn on, turns off suddenly, has a "service battery" warning, or simply won't hold a charge, this replacement battery may be what you need to fix it. Our aftermarket replacement batteries lead the industry in quality and reliability, so you know you're getting the best money can buy.
Contenuto del kit
- New Replacement Battery Compatible with a MacBook Air 11" (Mid 2011-Early 2015)
- Spudger
- iFixit Precision Bit Driver
- Precision 4 mm Bits:
- Pentalobe P5
- Torx T5
Compatibilità
- MacBook Air 11" A1370 Mid 2011
- MacBook Air 11" A1465 Mid 2012 to Early 2015
Specifiche
Compatibilità
Visualizza 2 altri dispositivi
Guide Sostituzione
MacBook Air 11" Early 2014 Battery Replacement
Difficoltà:
Moderato
MacBook Air 11" Early 2015 Battery Replacement
Difficoltà:
Moderato
MacBook Air 11" Mid 2011 Battery Replacement
Difficoltà:
Moderato
MacBook Air 11" Mid 2012 Battery Replacement
Difficoltà:
Moderato
MacBook Air 11" Mid 2013 Battery Replacement
Difficoltà:
Moderato
Recensioni dei clienti
