Parts Mac MacBook MacBook 13" (Model A1181) Logic Boards
Store
Grab a toolkit for your MacBook 13" (Model A1181) model and fix your broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
Non sai qual è il tuo modello? ID del tuo Mac
MacBook Core Duo 1.83 GHz Logic Board
Replace a 1.83 GHz logic board (motherboard) compatible with the MacBook Core Duo model laptop. Fix processing issues like unexpected shutdowns, reboots or water damage. ...
99,99 USD
MacBook Core Duo 2 GHz Logic Board
Replace a 2 GHz logic board (motherboard) compatible with the MacBook Core Duo. Fix processing issues like unexpected shutdowns, reboots or water damage. Included Ports: ...
109,99 USD
MacBook Core 2 Duo 1.83 GHz Logic Board / White
Replace a 1.83 GHz logic board (motherboard) compatible with the MacBook Core 2 Duo model laptop. Fix processing issues like unexpected shutdowns, reboots or water damage...
99,99 USD
MacBook Core 2 Duo 2 GHz (Energy Star) Logic Board
Replace a 2 GHz Energy Star logic board (motherboard) compatible with the MacBook Core 2 Duo model laptop. Fix processing issues like unexpected shutdowns, reboots or wat...
149,99 USD
MacBook Core 2 Duo 2.16 GHz (non-Energy Star) Logic Board
Replace a 2.16 GHz logic board (motherboard) compatible with the MacBook Core 2 Duo model laptop. Fix processing issues like unexpected shutdowns, reboots or water damage...
129,99 USD
MacBook Core 2 Duo 2.16 GHz (Energy Star) Logic Board
Replace a 2.16 GHz logic board (motherboard) compatible with the MacBook Core 2 Duo model laptop. Included Ports: Mini DVI Video Out, 1000BaseT Ethernet, Firewire 400, 2 ...
149,99 USD
MacBook Core 2 Duo 2.1 GHz Logic Board
Replace a 2.1 GHz logic board (motherboard) compatible with the MacBook Core 2 Duo model laptop. Fix processing issues like unexpected shutdowns, reboots or water damage....
74,99 USD
MacBook Core 2 Duo 2.4 GHz Logic Board
Replace a 2.4 GHz logic board (motherboard) compatible with the MacBook Core 2 Duo. Fix processing issues like unexpected shutdowns, reboots or water damage. Included Por...
189,99 USD
MacBook (Early 2009) 2 GHz Logic Board
Replace a 2 GHz logic board (motherboard) compatible with the Early 2009 MacBook. Ports: Mini-DVI Port, 1000BaseT Ethernet, Firewire 400, 2 USB 2.0, Audio in, Audio out. ...
299,99 USD
MacBook (Mid 2009) 2.13 GHz Logic Board
Replace a 2.13 GHz logic board (motherboard) compatible with the Mid 2009 MacBook. Fix processing issues like unexpected shutdowns, reboots or water damage. Ports: Mini-D...
Da 224,99 USD
Visualizzazione prodotti 1 - 10 di 10
Informazioni Dispositivo
All older MacBooks have the same A1181 model number. However, not all parts are compatible with every machine. Be sure to ID your Mac to ensure correct selection of your model above!
With the exception of the Mid 2009 model, all plastic MacBooks use PC2-5300 RAM, available in our parts store.
These machines are notorious for pieces of the upper case breaking off near the trackpad. Fortunately, it's easy to fix-- just use our repair guides to replace the upper case! Select your machine above to make sure you buy the right case component.
