MacBook 13" Early 2009 Logic Boards
Grab a toolkit for your MacBook 13" Early 2009 model and fix your broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
Parti che funzionano con MacBook 13" Early 2009:
MacBook (Early 2009) 2 GHz Logic Board
Replace a 2 GHz logic board (motherboard) compatible with the Early 2009 MacBook. Ports: Mini-DVI Port, 1000BaseT Ethernet, Firewire 400, 2 USB 2.0, Audio in, Audio out. ...
MacBook (Mid 2009) 2.13 GHz Logic Board
Replace a 2.13 GHz logic board (motherboard) compatible with the Mid 2009 MacBook. Fix processing issues like unexpected shutdowns, reboots or water damage. Ports: Mini-D...
Informazioni Dispositivo
For the Early 2009 version of the MacBook, Apple added liquid damage indicators on the upper case, logic board, and battery connector/sleep sensor. The optical drive is now SATA interface, making this machine incompatible with previous versions. Bluetooth has been updated to version 2.1.
The MacBook 13" 2 GHz (Early 2009) can be upgraded to a total of 8 GB of memory using two 4 GB RAM chips. Don't let all that RAM be wasted with a slow hard drive. The 750 GB 7200 RPM SATA Hard Drive Upgrade Kit will give you plenty of storage. The fastest optical drive for this model is the 8x SuperDrive and it will make burning CDs a breeze.
Check out our MacBook troubleshooting page for help in diagnosing your machine!
Select your category below or browse all compatible parts to find what you need to fix your laptop!
