Parti Mac MacBook 13" Core 2 Duo Hard Drives SATA
Store
Non sai qual è il tuo modello? ID del tuo Mac
Arctic Silver Thermal Paste
Forms a continuous, heat conductive layer between a processor and its heat sink. A new layer of thermal paste keeps your processor from overheating. 3.5 grams
8,99 US$
Arctic Silver ArctiClean
Two part cleaner dissolves old thermal paste on heat sinks and processors. One 30 ml bottle of thermal material remover and one 30 ml bottle of thermal surface purifier.
7,99 US$
MacBook and MacBook Pro (Non-Retina) SSD Upgrade Bundle
Upgrade the storage and improve boot time and read/write speed in your MacBook and MacBook Pro (Non-Retina) with this SSD upgrade bundle.
Da 89,99 US$
Universal Drive Adapter
Turn your current hard drive into an external drive with this part.
24,99 US$
Silicone 2.5" Hard Drive Enclosure with USB 2.0 Cable
Turn any SATA 2.5" laptop hard drive into an external storage drive with this part.
9,99 US$
PC2-5300 2 GB RAM Chip
Replace or upgrade the RAM in your desktop, laptop, or game console for faster performance. Low Profile / 200 pin / DDR-2 / 667 MHz
14,99 US$
500 GB 5400 RPM 2.5" Hard Drive / Toshiba
Replacement or upgrade hard drive compatible with all MacBooks, MacBook Pros, Intel Mac minis, and Sony PS3 and PS3 Slim game consoles. SATA interface for Intel Macs / 2....
54,99 US$
MacBook Replacement Battery / White / New
Replace your dying or broken battery with this replacement. Compatible with all 13.3" MacBooks (excluding MacBook Unibody and MacBook Air). 4900-5200 mAh, 55 Watt Hours (...
79,99 US$
G4/MagSafe AC Adapter End
Replace a broken or damaged two-pronged tip of your square G4 or MagSafe adapter with this part.
7,99 US$
MacBook Display Inverter
Replace a broken or damaged display inverter for your MacBook with this part and fix backlight issues. This part is compatible with all 13.3" MacBooks (excluding MacBook ...
14,99 US$
Visualizzazione prodotti 1 - 10 di 66
Informazioni Dispositivo
The Core 2 Duo MacBooks feature beefier processors, thanks to the Core 2 Duo chipset.
A total of 3 GB of memory (using a 2 GB RAM chip and a 1 GB RAM chip) will max out your machine's capacity. The biggest hard drive that can currently be put into these laptops is the 500 GB 7200 RPM SATA hard drive. The 8x SuperDrive is the fastest optical drive for these models and will make creating DVDs a whiz. You can also upgrade the upper case to the Penryn/Santa Rosa version with the new keyboard layout (including iTunes controls)!
There is one main variation within these models. Your machine may be a Energy Star-equipped or non-Energy star version. This affects the battery connector and logic board. See photos and part descriptions on the non-Energy Star or Energy Star battery connector/sleep sensors for information on determining which version you have.
Check out our MacBook troubleshooting page for help in diagnosing your machine!
Select your model above or browse all compatible parts to find what you need to fix your laptop!
