12.7 mm PATA Optical Bay SATA Hard Drive Enclosure
  • 12.7 mm PATA Optical Bay SATA Hard Drive Enclosure
Non in vendita
Non in Vendita
Non in Vendita
Diffondi allegria Fixmas
Ottieni $12 sul tuo acquisto di $50 o più con il codice FIXMAS12
Dettagli Prodotto
Descrizione
Descrizione
Increase the storage space in your laptop by replacing the optical drive with a second SATA hard drive or SSD.
Video di Installazione
Compatibilità
iMac Intel 20" EMC 2105 and 2118
2 GHz
2.16 GHz
2.33 GHz
iMac Intel 20" EMC 2133 and 2210
2 GHz (EMC No. 2133)
2.4 GHz (EMC No. 2133)
2.4 GHz (EMC No. 2210)
2.66 GHz (EMC No. 2210)
iMac Intel 24" EMC 2111
2.16 GHz
2.33 GHz
iMac Intel 24" EMC 2134 and 2211
2.8 GHz (EMC No. 2134)
2.8 GHz (EMC No. 2211)
3.06 GHz (EMC No. 2211)
Mac Mini Model A1176
1.5 GHz (Core Solo)
1.66 GHz (Core Duo, Early 2006)
1.66 GHz (Core Duo, Late 2006)
1.83 GHz (Core 2 Duo, Mid 2007)
1.83 GHz (Core Duo, Late 2006)
2 GHz (Core 2 Duo)
MacBook Pro 17" Models A1151 A1212 A1229 and A1261
2.16 GHz (Core Duo)
2.33 GHz (Core 2 Duo)
2.4 GHz (Santa Rosa)
2.5 GHz (Penryn)
2.6 GHz (Penryn)
2.6 GHz (Santa Rosa)
Visualizza 3 altri dispositivi
Storie di Riparazione
Il Mio Problema
CD player broken.
La Mia Riparazione
I followed the instructions online and it worked flawlessly!
Il Mio Consiglio
Not hard to do if you check the instruction videos.
Il Mio Problema
Optical drive on macmini a1176 wouldn't give up the discs anymore. Found the solution on iFixit which was to drop in a hard drive using their caddy/enclosure and a 2.5" drive I had already.
La Mia Riparazione
Very smooth and most importantly, it worked the FIRST time. It helps if you've opened older mac minis before an . . .
Il Mio Problema
Broken optical drive on my old machine I don't have the heart to replace with a flashy new model, libraries are wayyy too big for the 160gb original HD and don't use compact disks too often anymore, so decided to add a TB
La Mia Riparazione
so easy! Doesn't even screw in just sits right where optical drive was.
Il Mio Consiglio
Remembe . . .
Il Mio Problema
This is a project that was kind of dumb to get into. Tearing apart an
old iMac I only use to run my scanner because the optical drive was
croaked and i wanted to change the boot to SSD. Once you have a computer that boots up quickly you get spoiled.
La Mia Riparazione
it was a lot more work than I anticipated. But your . . .
Il Mio Problema
Running Yosemite, my early 2008 iMac had been reduced to a crawl. It would take minutes to boot and even wake from sleep. Mail took forever to load. iPhoto took even longer. Every app spawned spinning beachballs that seemed to never go away. Streaming audio would too often just stop for no reason. M . . .
Il Mio Problema
Received a 24" 2008 iMac (2GB RAM, 2.8 duo-core) hand-me-down that had potential, but was slow and had a smaller internal HDD. I'm unfamiliar with Mac's, but I also had an unused 120GB SSD laying around and figured I would tinker to learn Mac.
La Mia Riparazione
I decided to kill two birds with one stone and swap the m . . .
Il Mio Problema
There was really no problem. Just decided to buy an old 17" macbook pro and see what could be done with it. I wound up with an early 2008 from ebay - really cheap. It already had an SSD installed in place of the original HDD. I upgraded the RAM to the maximum of 6 GB and bought a 1 Tb HDD. You . . .
Il Mio Problema
I had replaced the stock HDD on A1261 Macbook Pro 4,1 with an SSD. While this was better, I did not have enough storage. For that reason I installed a platter drive in the superdrive space and created a "Fusion Drive." Now I have 1.25 TB of storage that really screams.
La Mia Riparazione
It was easy, but I have experi . . .
Il Mio Problema
He was having issues with his mac being very slow and was running an older OS.
La Mia Riparazione
I replaced the original 3.5 hdd with a 2.5 ssd and used a hdd adapter. I also installed an optical drive to hdd adapter sold by ifixit and placed a 500gb hdd here. The reason I swapped the two is on this iMac the optical d . . .
Il Mio Problema
My old hhd was failing, so instead of just replacing it, I decided to upgrade to a fusion drive.
La Mia Riparazione
For best results with a fusion drive, the hhd should go in the optical drive enclosure and the ssd should go where the original hdd was. This meant using a 2.5" to 3.5" SATA adapter to hold the drive in . . .
Mostra di più
