1 TB 7200 RPM 3.5" Hard Drive
  • 1 TB 7200 RPM 3.5" Hard Drive
  • 1 TB 7200 RPM 3.5" Hard Drive / Seagate
Model #: DT01ACA100,
Cache: 32MB
59,99 US$
59,99 US$
Ti invieremo un messaggio quando il prodotto sarà nuovamente disponibile.
Dettagli Prodotto
Descrizione
Descrizione
Replace or upgrade the hard drive in your compatible iMac with this part.
Nota
To ensure compatibility with the 2009 and 2010 21.5" or 27" iMac, the replacement hard drive must be of the same brand as the original. The model number of the hard drive does not matter as long as the brand matches. 2011 and up iMacs cannot be supported by us.
Nota
Works only in iMac G5s and Intel iMacs (excluding 2011 and up 21.5" and 27" models).
Compatibilità
iMac G5 17" Model A1058
1.8 GHz (EMC No. 2055)
2 GHz
iMac G5 17" Model A1144
1.9 GHz
iMac G5 20" Model A1076
1.8 GHz
2 GHz
iMac G5 20" Model A1145
2.1 GHz
iMac Intel 17"
1.83 GHz (EMC No. 2104)
1.83 GHz (EMC No. 2110)
1.83 GHz (EMC No. 2124)
2 GHz
2.16 GHz
iMac Intel 20" EMC 2105 and 2118
2 GHz
2.16 GHz
2.33 GHz
iMac Intel 20" EMC 2133 and 2210
2 GHz (EMC No. 2133)
2.4 GHz (EMC No. 2133)
2.4 GHz (EMC No. 2210)
2.66 GHz (EMC No. 2210)
iMac Intel 20" EMC 2266
2.66 GHz
iMac Intel 21.5" EMC 2308
EMC 2308 3.06 GHz
EMC 2308 3.33 GHz
iMac Intel 21.5" EMC 2389
EMC 2389 3.06 GHz
EMC 2389 3.2 GHz
EMC 2389 3.6 GHz
iMac Intel 24" EMC 2111
2.16 GHz
2.33 GHz
iMac Intel 24" EMC 2134 and 2211
2.4 GHz (EMC No. 2134)
2.8 GHz (EMC No. 2134)
2.8 GHz (EMC No. 2211)
3.06 GHz (EMC No. 2211)
iMac Intel 24" EMC 2267
2.66 GHz
2.93 GHz
3.06 GHz
iMac Intel 27" EMC 2309 and 2374
2.66 GHz (Late 2009)
2.8 GHz (Late 2009)
3.06 GHz (Late 2009)
3.33 GHz (Late 2009)
iMac Intel 27" EMC 2390
2.8 GHz (Mid 2010)
2.93 GHz (Mid 2010)
3.2 GHz (Mid 2010)
3.6 GHz (Mid 2010)
Power Mac G5
1.6 GHz
1.8 GHz (EMC No. 1969)
1.8 GHz (Late 2004)
1.8 GHz Dual (EMC No. 1969)
1.8 GHz Dual (EMC No. 1969C)
2.0 GHz Dual (EMC No. 1969)
2.0 GHz Dual (EMC No. 1969C)
2.0 GHz Dual (EMC No. 2023)
2.0 GHz Dual (EMC No. 2061)
2.3 GHz Dual (EMC No. 2023)
2.3 GHz Dual (EMC No. 2061)
2.5 GHz Dual (EMC No. 1969C)
2.5 GHz Quad
2.7 GHz Dual
Visualizza 13 altri dispositivi
Storie di Riparazione
Jane Pearson's Story Photo #1123352
Jane Pearson's Story Photo #1123351
Jane Pearson's Story Photo #1123349
Il Mio Problema
Computer wouldn't boot even after trying multiple resets and safe boots. Attempted to erase hard drive but could not load OS. Decided to replace drive.
La Mia Riparazione
The video and step by step directions made replacing the drive a breeze. My 16 year old son (who has autism) and I followed the directions and fixed . . .
Jon Mikelonis's Story Photo #867616
Jon Mikelonis's Story Photo #867617
Jon Mikelonis's Story Photo #867618
Il Mio Problema
Let me start off by saying I am a DIY type by nature and I was born in 1971. Therefore, being DIY for me means I am more familiar with carburetors, brakes, and camshaft installations than hard drive replacement. However, my age does not change my mental disposition to FIXIT myself. When something (a . . .
Il Mio Problema
iMac internal hard drive failed and needed to replace to use computer.
La Mia Riparazione
Had my 9 year old son help read instructions while i was doing the work, as my hands were busy. I sprayed out the computer from dust accumulated over the last 8 years, which took me longer than the 1 hour it could have.
Il Mio Consiglio
When bootin . . .
Il Mio Problema
Hard drive Failed
La Mia Riparazione
Perfect as instructed.
Il Mio Consiglio
You don’t need to buy any suction cups. Do you have packing tape? Lay it across the screen at the top through two loops of tape in the corners. Pull. The other tool recommended, the stick, I don’t know what it’s for, but I didn’t need it. Just torx . . .
Il Mio Problema
Hard drive failed and it was quoted at $500 to install a new one.
La Mia Riparazione
Repair went great! Step by step instructions with photos made it super easy.
Il Mio Consiglio
Don't be intimidated! It's actually quite easy!
Il Mio Problema
I did not fix any problem, I'd rather upgraded my iMac 21,5 late 2009 with a new HD
La Mia Riparazione
Everything went just fine
Il Mio Consiglio
The repair guides are absolutely helpful. Awesome
Il Mio Problema
Old drive died!
La Mia Riparazione
Smooth replacement, a bit dusty inside.
Il Mio Consiglio
Keep an eye out for the mic wires when reinstalling the display
Il Mio Problema
I had to replace a dead hard drive
La Mia Riparazione
It wasn't bad at all. The hard drive that was sent was not the same in the iMac. This means I could not use the thermal sensor. However, I found a website that allowed me to use it. Besides having big fingers, it wasn't that bad.
Il Mio Consiglio
Have another person helping you. When . . .
Il Mio Problema
Hard Drive failed on computer. Since it was seven years old, bought new iMac and decided to repair this old.
La Mia Riparazione
The repair essentially went as advertised except for item listed below.
Il Mio Consiglio
Had to do in stages as instructions stated need same manufacturer for hard drive so that temperature monitor connection . . .
Il Mio Problema
The original had become unusable. Too many sectors gone bad.
La Mia Riparazione
The iFixit PDF was almost dead on accurate.
Il Mio Consiglio
In my particular case, the thermal sensor cable warnings didn't apply. The connections were built as such that there is only one way to plug it in if it was to be plugged in at all. Now this might . . .
Mostra di più
