Salta al contenuto principale
Guida Archiviata
Questa guida è mantenuta solo per scopi storici. Usa la versione aggiornata della guida per eseguire la riparazione.
Cosa ti serve
Questo smontaggio non è una guida di riparazione. Per riparare il tuo iPhone 6, usa il nostro manuale di assistenza.
  1. iPhone 6 Teardown, iPhone 6 Teardown: passo 1, immagine 1 di 3 iPhone 6 Teardown, iPhone 6 Teardown: passo 1, immagine 2 di 3 iPhone 6 Teardown, iPhone 6 Teardown: passo 1, immagine 3 di 3
    • Unboxing the iPhone 6: yup, it's a phone.
  2. iPhone 6 Teardown: passo 2, immagine 1 di 1
    • After removing the familiar two Pentalobe screws we use a suction cup to carefully lift up the screen to give us enough space to run a plastic tool down the edges to release the screen clips
    • Unlike the 5s, The 6 Touch ID cable is now routed up the back of the screen, so we don't have to worry about accidentally ripping the touch ID cable.
  3. iPhone 6 Teardown: passo 3, immagine 1 di 2 iPhone 6 Teardown: passo 3, immagine 2 di 2
    • The screen connectors are covered by a metal plate, similar to the previous models.
    • This plate is held by 5 screws this time.
    • There are 5 connectors under this plate: LCD/Touch Sensor/Front Camera, Rear Camera and TouchID.
  4. iPhone 6 Teardown: passo 4, immagine 1 di 2 iPhone 6 Teardown: passo 4, immagine 2 di 2
    • The battery is very well stuck in. With a bit of heat and a little deformation of the battery, we were able to get it out. (There's probably a pull tab to remove the battery, but we didn't find it.)
    • The battery is rated at 3.82V, 6.91Whr.
  5. iPhone 6 Teardown: passo 5, immagine 1 di 1
    • Removing the logic board requires the removal of many screws.
    • Fortunately for DIYers, Apple have placed the chips away from most of the screws so there is less risk of tool slip damage.
  6. iPhone 6 Teardown: passo 6, immagine 1 di 1
    • The iPhone 6 rear camera: not as big as its optically stabilized brother.
  7. iPhone 6 Teardown: passo 7, immagine 1 di 1
    • The iPhone 6 logic board.
  8. iPhone 6 Teardown: passo 8, immagine 1 di 1
    • The vibration motor is now inside a metal case!
  9. iPhone 6 Teardown: passo 9, immagine 1 di 1
    • The loudspeaker.
  10. iPhone 6 Teardown: passo 10, immagine 1 di 1
    • The Lightning port.
  11. iPhone 6 Teardown: passo 11, immagine 1 di 1
    • The Touch ID sensor.
  12. iPhone 6 Teardown: passo 12, immagine 1 di 1
    • The front camera and proximity sensor flex cable.
  13. iPhone 6 Teardown: passo 13, immagine 1 di 3 iPhone 6 Teardown: passo 13, immagine 2 di 3 iPhone 6 Teardown: passo 13, immagine 3 di 3
    • The iPhone 6 display assembly. It's thinner than the iPhone 5s/5c/5 screen.
    • The Touch ID Cable runs from the home switch to the top of the screen, adding a 4th connector at the top.
  14. iPhone 6 Teardown: passo 14, immagine 1 di 3 iPhone 6 Teardown: passo 14, immagine 2 di 3 iPhone 6 Teardown: passo 14, immagine 3 di 3
    • After the usual painful desoldering of the shielding, we have the logic board in all its naked glory.
    • Analysis to follow with iFixit's full teardown.
  15. iPhone 6 Teardown: passo 15, immagine 1 di 3 iPhone 6 Teardown: passo 15, immagine 2 di 3 iPhone 6 Teardown: passo 15, immagine 3 di 3
    • More chip pics!
  16. iPhone 6 Teardown: passo 16, immagine 1 di 3 iPhone 6 Teardown: passo 16, immagine 2 di 3 iPhone 6 Teardown: passo 16, immagine 3 di 3
    • Even more ICs.
  17. iPhone 6 Teardown: passo 17, immagine 1 di 2 iPhone 6 Teardown: passo 17, immagine 2 di 2
    • And that's all she wrote! We'll be back soon with a complete teardown and analysis from iFixit with higher resolution photos.
Patrick Lee
Membro da: 09/19/13
2.605 Reputazione
1 Guida realizzata
iExperts Membro di iExperts
Business
1 Membro
1 Guida realizzata
Un commento
I have 2 small pieces that fell out and I have no idea where they go. One has this code on it 1-00095A 344. And the other looks like a toggle switch, it is black. Can you help.
linda.lloyd - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 87,133
