iPad Pro 12.9" 5th Gen Teardown
Pubblicato: June 8, 2021
- Commenti: 13
- Preferiti: 0
- Visualizzazioni: 43,5k
- Commenti: 13
- Preferiti: 0
Smontaggio
Introduzione
In this teardown video we uncover the M1 SoC inside the new 12.9” iPad, then explore the new mini-LED-powered XDR display and explain what makes it so different from Apple’s other Liquid Retina iPad displays.
Istruzioni Video
Questo smontaggio non è una guida di riparazione. Per riparare il tuo iPad Pro 12.9" 5th Gen, usa il nostro manuale di assistenza.
Incorpora questa guida
Scegli una dimensione e copia il codice qui sotto per incorporare questa guida come un piccolo widget sul tuo sito / forum.
13 Commenti
I know it’s not the focus of the video, but it’s great to see that the PMIC is cooled via a thermal pad at least. I wonder if the M1 is undervolted to fit the iPad’s power and thermal constraints as well.
Ethan Zuo - Replica
Does the new iPads have reinforced sides (mic hole and apple pencil charge window), so they don’t bend as easy as the first gen? In Jerryrigeverything’s new video this iPad passes the bend test.
michalmajdak - Replica
if you guys can show pictures with all the magnet positions would be awesome, it’s impossible to find the information online
Razvan Costel Vladu - Replica
Because all of the full-screen iPads are inter-compatible with the magnetic iPad accessories [Magic Keyboard, Smart Keyboard Folio, Smart Folio, Apple Pencil 2nd generation (heh)], I assume the magnet arrays are identical. Therefore, you can go take a look at the 3rd generation 12.9-inch iPad Pro teardown, or the 1st generation 11-inch iPad Pro teardown as they do contain these X-Ray graphs.
KillerLab 233 -
Do you guys know what is the IC Chip and what is the Transceiver in this new iPad Pro model?
Victoria - Replica
