Salta al contenuto principale
Cosa ti serve
Questo smontaggio non è una guida di riparazione. Per riparare il tuo Withings Activité Smartwatch, usa il nostro manuale di assistenza.
  1. Withings Activité Pop Smartwatch Teardown, Introduction, remove the rubber band: passo 1, immagine 1 di 3 Withings Activité Pop Smartwatch Teardown, Introduction, remove the rubber band: passo 1, immagine 2 di 3 Withings Activité Pop Smartwatch Teardown, Introduction, remove the rubber band: passo 1, immagine 3 di 3
    • This is Withings Activité Pop Smartwatch. A beautifully designed no frills smartwatch that shows your daily activity score with an analogue gauge. Remove the rubber band by pulling tiny levers at the back along arrow direction.
  2. Withings Activité Pop Smartwatch Teardown, Remove case back and access the battery: passo 2, immagine 1 di 3 Withings Activité Pop Smartwatch Teardown, Remove case back and access the battery: passo 2, immagine 2 di 3 Withings Activité Pop Smartwatch Teardown, Remove case back and access the battery: passo 2, immagine 3 di 3
    • The case back can be opened by prying with the opening tool or a flat screwdriver. You will see the CR2025 lithium battery shining with all its glory.
  3. Withings Activité Pop Smartwatch Teardown, Remove the lithium battery: passo 3, immagine 1 di 2 Withings Activité Pop Smartwatch Teardown, Remove the lithium battery: passo 3, immagine 2 di 2
    • Pry the CR2025 lithium battery off and ponder the meaning of three hexadecimal numbers on the information sticker.
  4. Withings Activité Pop Smartwatch Teardown, Remove the inner plastic cover: passo 4, immagine 1 di 3 Withings Activité Pop Smartwatch Teardown, Remove the inner plastic cover: passo 4, immagine 2 di 3 Withings Activité Pop Smartwatch Teardown, Remove the inner plastic cover: passo 4, immagine 3 di 3
    • Using a thin flat blade screwdriver remove three self tapping screws holding the inner plastic cover. The vibration motor (round metal part in second photo) has a sticky tape on it. You may need to apply force to separate the motor from the inner plastic cover. See the main PCB.
  5. Withings Activité Pop Smartwatch Teardown, Access and remove the main PCB: passo 5, immagine 1 di 3 Withings Activité Pop Smartwatch Teardown, Access and remove the main PCB: passo 5, immagine 2 di 3 Withings Activité Pop Smartwatch Teardown, Access and remove the main PCB: passo 5, immagine 3 di 3
    • Using a thin flat blade screwdriver remove 12 (!) fine threaded screws to release the main PCB from the stepper motors of three dial hands.
  6. Withings Activité Pop Smartwatch Teardown, Have a close look at the main PCB: passo 6, immagine 1 di 2 Withings Activité Pop Smartwatch Teardown, Have a close look at the main PCB: passo 6, immagine 2 di 2
    • ...and enjoy the view.
  7. Withings Activité Pop Smartwatch Teardown, Have a close look at the three stepper motors: passo 7, immagine 1 di 2 Withings Activité Pop Smartwatch Teardown, Have a close look at the three stepper motors: passo 7, immagine 2 di 2
  8. Withings Activité Pop Smartwatch Teardown, Teardown complete...: passo 8, immagine 1 di 1
    • This Withings Activité Pop Smartwatch had water ingress and it failed due to corrosion. A common fault with this watch is loose inner screws, leading to poor PCB contact with motors. When you change battery make sure you apply silicone grease on the rubber gasket of the case back. The dial and hands are not accessible since the glass is pressed.
Koray
Membro da: 03/05/17
903 Reputazione
3 Guide realizzate
4 Commenti
Great guide with wonderful photos! Thank you for contribution.
Christopher Fernandes - Replica
Great guide!! Is it possible to access the front face? I’d like to put some luminescent paint on it.
Giorgi - Replica
Wow es espectacular. Alguien tendra el steel HR que trae para los mensaje y todo eso.
Roldf RR Rodriguez Prévôt - Replica
It seems the inner battery is the same as the Steel HR, does anyone know where buy one ?
Fabien Bataille - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 17
Ultimi 30 Giorni: 75
Tutti i Tempi: 10,576
