Cosa ti serve
For the teardown I'll be using the iFixIt Protech Toolkit. It has everything I need and all tools required to do the teardown
The first step doesn't require any tools.
On the back you can take off the back in the left-bottom corner
Something we haven't seen since iPhone got invented. Removable and Replacable battery
Under the battery you'll find a slot for a Micro SD card (Not included, added it myself) and a SIM card slot
Now we have to remove the vibration motor, don't be fooled (Like I was), this is NOT a battery! (Thanks for correcting me Pawel)
For this I used a simple tweezers
Next we need to remove the 4 screws in the corners, These can be removed with a 00 head
With the 4 screws removed, we can remove the top layer.
On the bottom and on the left top there's the speaker
Is this what they mean with integrated audio?
We can now also remove the band from the watch.
If we look closer, inside the band, there's the GSM Antenna (Thanks for the tip Pawel!)
If there's anything that can't stop us at iFixIt, it's gotta be this. Simply use the Tweezers from your iFixIt Protech Toolkit and your good to go
Before taking off the board, there's 2 cables you need to unplug first!
Note the 2 cables are locked so you'll need to simply push up the lock so you can take out the cables, do this with accuracy and precision, using Tweezers!
Now we can take out the board!
And now we've come to the end.
In such a small device, so much functions. We've learned a lot today.
We also learned that a iPhone 5C Camera is no good at taking pictures at close distance!
