If the device is still running, please turn the computer off properly and then disconnect the power supply from the power supply port in the back of the computer.
Remove battery before beginning any work to reduce electrical shock and to prevent damage to the electrical components.
Locate and slide the 2-battery locks to disconnect the battery.
Remove the battery by sliding it out away from the computer (horizontal with the casing).
Remove the ODD screw with a #1 Phillips head screwdriver as indicated in the picture.
Using a flat edge tool, pry it the drive out of it slot from the side of the casing. You can then use your hands to continue pulling the rest the way out of its slot.
Use a #1 Phillips head screwdriver to remove the screws on the RAM's cover panel, as seen in image.
Then, use a flat edge tool to pry the cover off, as seen in image.
Use your fingers to push the RAM tabs, as seen in image, that secure the RAM outward (away from the RAM). The RAM should then pop up.
Finally, gently pull the RAM away from the connection. (Repeat this process until all the RAM has been removed from the device).
Remove the hard drive screw labeled with a #1 Phillips head screwdriver as indicated in the picture, then use a flat edge tool to pry the cover off.
Use the plastic flap to pull the hard drive out of its slot.
Remove the panel screw labeled with a #1 Phillips head screwdriver as indicated in the picture, then use a flat edge tool to pry the cover off.
The hardware to the left (labeled) can be easily removed by disconnecting the black and white wires and pushing the tabs that secure it (located on the side) outwards.
Pull the Wi-Fi card out from the device at a slight angle (horizontal with the casing).
Remove the keyboard. For keyboard removal instructions, see the keyboard guide here: Toshiba Satellite M45 Keyboard Replacement
Remove the black electrical tape covering the black-and-white antenna cable. There will be 2-3 pieces of tape.
After the tape has been removed, close the laptop display, flip the laptop over, and disconnect the black-and-white antenna cables from the WiFi Card.
For information about accessing the WiFi Card, see the WiFi Guide here: Toshiba Satellite M45 Wi-Fi Card Replacement
Once the antenna cables are disconnected from the modem card, flip the laptop back over and open the display.
Remove the two screws securing the display hinges with a #1 size Phillips head screwdriver. It is recommended to keep the screws in a small cup so that you don't lose them.
Remove the four screws on the back of the laptop holding the screen in place with a #1 screwdriver. There are two on each side.
Carefully pry the panel above the keyboard from both sides of the laptop using the iFixit opening tool.
Push back the screen until it is horizontal with the laptop.
Gently remove the clips that connect the panel to the screen.
Located near the upper edges of the motherboard you will find the 2-speaker wires that trace to the speakers. You will see these white tab with black and red wires.
Unscrew the 2-screws located above the speakers to remove them. Slowly pull up on the speakers as there are other port connectors are located near the wiring.
Disconnect the video cable near the left speaker slowly but firmly pulling upwards.
Disconnect the brown ribbon that is located directly in the middle of where the keyboard one was away from the connector.
Disconnect the 2-other white ribbons located near the top right half of the keyboard section pulling firmly away from the connector.
Congratulations, your computer has been completely dismantled!
Now, reverse the steps to reassemble.
