Salta al contenuto principale
Cosa ti serve
Questo smontaggio non è una guida di riparazione. Per riparare il tuo Texas Insturments TI-84 Plus Color Silver Edition, usa il nostro manuale di assistenza.
  1. Texas Insturments TI-84 Plus Color Silver Edition Teardown, Take battery cover off: passo 1, immagine 1 di 3 Texas Insturments TI-84 Plus Color Silver Edition Teardown, Take battery cover off: passo 1, immagine 2 di 3 Texas Insturments TI-84 Plus Color Silver Edition Teardown, Take battery cover off: passo 1, immagine 3 di 3
    • Wisdom
  2. Texas Insturments TI-84 Plus Color Silver Edition Teardown, Take out the battery: passo 2, immagine 1 di 2 Texas Insturments TI-84 Plus Color Silver Edition Teardown, Take out the battery: passo 2, immagine 2 di 2
    • Unplug the battery.
    • Be careful not to fray cable while unplugging.
  3. Texas Insturments TI-84 Plus Color Silver Edition Teardown, Remove the back cover/ front button shield: passo 3, immagine 1 di 3 Texas Insturments TI-84 Plus Color Silver Edition Teardown, Remove the back cover/ front button shield: passo 3, immagine 2 di 3 Texas Insturments TI-84 Plus Color Silver Edition Teardown, Remove the back cover/ front button shield: passo 3, immagine 3 di 3
    • Remove the back cover by removing the 6 Pentalobe screws (P6)
    • The front cover can be taken off by prying it off from the front of the device
    • Then pry off the back cover it can be a little challenging but take your time
  4. Texas Insturments TI-84 Plus Color Silver Edition Teardown, Disassemble the mother board: passo 4, immagine 1 di 3 Texas Insturments TI-84 Plus Color Silver Edition Teardown, Disassemble the mother board: passo 4, immagine 2 di 3 Texas Insturments TI-84 Plus Color Silver Edition Teardown, Disassemble the mother board: passo 4, immagine 3 di 3
    • Remove the 6 Philips screws holding the mother board and if you want remove the foil just to see the full board itself
    • To change out the buttons take out the grey rubber sheet that separates them from the board (be careful with the buttons as they will fall out)
ArabianBoi1259
Membro da: 04/03/20
103 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 9
Tutti i Tempi: 458
