Salta al contenuto principale
Cosa ti serve
Questo smontaggio non è una guida di riparazione. Per riparare il tuo String Cheese, usa il nostro manuale di assistenza.
    • Be cautious when using the iOpener for opening the adhesive on the cheese packaging.
    • Inspect the string cheese packaging. You should see a perforated corner that you can stick the tip of your spudger into.
    • Once you put the tip of the spudger into the plastic pull the corner with your other hand, guiding the spudger along as you peel back the packaging.
    • We're in to the GOOD stuff,
    • Pull up on the cheese to get it unstuck from the adhesive
    • Then peal the last bits of adhesive away
    • YOU CANT PUT IT BACK TOGETHER
Ben Capehart
Membro da: 06/09/21
10.039 Reputazione
18 Guide realizzate
Restart Project Membro di Restart Project
Local Repair Groups
26 Membri
376 Guide realizzate
19Commenti sulla guida
@beanman56
This it a great teardown >:-D
Can we see a teardown on a strawberry?
HelloMacOS - Replica
@hellomacos - Help if you want
Ben Capehart -
Sure ,what do you want me to do?
HelloMacOS -
@hellomacos - Idk do what you want X-D
Ben Capehart -
@hellomacos - Will Do! >:-D
[collegamento guida non valido]
Ben Capehart - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 17
Tutti i Tempi: 431
