Introduzione
Have a look at the inside of Sony Xperia Z3 Dual and let you know where is component when need repair.
Witrigs is specialized in cellphone accessories and kinds of replacement guide.
Questo smontaggio non è una guida di riparazione. Per riparare il tuo Sony Xperia Z3 Dual, usa il nostro manuale di assistenza.
Remove two SIM card trays.
  • Remove two SIM card trays.
  • Heat the back cover to soften the adhesive sticker.
  • Place the suction cup and to open a gap from top side.
Aggiungi Commento
Insert the guitar pick into the opening gap.
  • Insert the guitar pick into the opening gap.
  • Slide the guitar pick to cut the adhesive sticker. Attention: when deal with the left side, the guitar pick would better go as the direction of the mark.
Aggiungi Commento
  • Release battery connector.
  • Free the fastening sticker.
Aggiungi Commento
  • Pry up and remove the battery.
  • 3100mAh battery.
Aggiungi Commento
  • Twist off screws.
Aggiungi Commento
  • Remove three pieces of securing bracket.
Aggiungi Commento
  • Release all the connectors.
  • Remove sim tray before removing motherboard.
  • Remove the motherboard carefully.
Aggiungi Commento
  • That's Sony Xperia Z3 Dual motherboard.
Aggiungi Commento
  • Remove front camera and rear camera.
Aggiungi Commento
  • Remove that blocker beside the earpiece speaker at first.
  • And then you can pry up the earpiece speaker and remove it.
Aggiungi Commento
  • Remove transparent securing cover beside of earphone jack.
Aggiungi Commento
  • Pry to turn the flex cover on the earphone jack. But it's a part of the earphone jack assembly.
  • Cut the adhesive sticker between the earphone jack and midframe and remove the assembly.
Aggiungi Commento
  • That's antenna signal flex.
Aggiungi Commento
  • Twist off screws.
  • Release connectors.
  • Remove vibrator securing bracket.
Aggiungi Commento
  • Remove loudspeaker assembly securing bracket. And there is no any adhesive.
  • Pry up and remove the loudspeaker assembly. No adhesive, too.
Aggiungi Commento
  • Done.
Aggiungi Commento
Sophia
Membro da: 25/03/2014
40.277 Reputazione
62 Guide realizzate
Can you put it back together?
zarixevolve - Replica
I dropped mine so I just want to take the battery out is it possibly to take it and then put it back in
hi.after changing my xperia z3 dual lcd 3 times.i hade a fluctuating and very week 3g and 4g signal.plz tell me where is the antenna located.i know that there is a flex and a board and antenna cover.what should i change.thanx
zein hamza - Replica
That's not a complete teardown. I would like to see the onboard chips and info's.
emmanuelhelene15 - Replica
Where can i buy the Sony Xperia Z3 plus Dual motherboard ?
I really need it.
Kwar Kwar - Replica
i need board from where i purchase please guaid me
haseebmustafa1212 - Replica
Hi Sofiya,
That's a great write-up.
My mobile repair guy is attending my mobile (sony Z3- single sim) for antenna- it is unable to receive phone network signal properly. He says he has to replace the antenna mother-board. But from your write-up I don't find any such mother board- is my repair guy conning me?
Thanks
Sundar
sundar ram - Replica
how many this LCD ? rupiah
mochamad kudori - Replica
How much this LCD? Rupiah’s
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 62
Ultimi 30 Giorni: 276
Tutti i Tempi: 32,230
