Salta al contenuto principale
Cosa ti serve
Questo smontaggio non è una guida di riparazione. Per riparare il tuo Sony DVD Player, usa il nostro manuale di assistenza.
  1. Sony DVD VHS Player  Teardown, Sony DVD VHS Player  Teardown: passo 1, immagine 1 di 2 Sony DVD VHS Player  Teardown, Sony DVD VHS Player  Teardown: passo 1, immagine 2 di 2
    • This is the device we will be tearing down.
  2. Sony DVD VHS Player  Teardown: passo 2, immagine 1 di 1
    • First, you need to remove the three black screws on the back.
  3. Sony DVD VHS Player  Teardown: passo 3, immagine 1 di 1
    • Now, you need to remove the cover by lifting it up like you would the cover of a shoe box, but it will come off. But before you do that you will need to unhook it by unclipping the clips on the back.
  4. Sony DVD VHS Player  Teardown: passo 4, immagine 1 di 1
    • You must now remove the silver bar attached to the VHS receptor.
  5. Sony DVD VHS Player  Teardown: passo 5, immagine 1 di 1
    • Once you have removed that silver bar you will now unscrew and remove the DVD Disc tray.
  6. Sony DVD VHS Player  Teardown: passo 6, immagine 1 di 2 Sony DVD VHS Player  Teardown: passo 6, immagine 2 di 2
    • Now that the DVD tray is out of the way, you can remove the smaller motherboard, the green one to specify easier. You will do this by removing the screws that hold it in.
  7. Sony DVD VHS Player  Teardown: passo 7, immagine 1 di 3 Sony DVD VHS Player  Teardown: passo 7, immagine 2 di 3 Sony DVD VHS Player  Teardown: passo 7, immagine 3 di 3
    • Now you can unscrew the VHS receptor and remove that to be able to access, unscrew and remove the final piece, the large motherboard.
  8. Sony DVD VHS Player  Teardown: passo 8, immagine 1 di 3 Sony DVD VHS Player  Teardown: passo 8, immagine 2 di 3 Sony DVD VHS Player  Teardown: passo 8, immagine 3 di 3
    • Now, you will remove the large, orange motherboard. You will need to unscrew it and pop it out. You MUST be careful as this piece is extremely fragile, and the smallest fracture or damage will cause it to no longer work.
Blake Sullivan
Membro da: 04/20/18
185 Reputazione
1 Guida realizzata
Un commento
Wish I could repair the DVD no luck in finding part the part
Joseph Pigott - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 16
Tutti i Tempi: 2,335
