Complete teardown of Sidekick II
Questo smontaggio non è una guida di riparazione. Per riparare il tuo Sidekick II, usa il nostro manuale di assistenza.
Use the plastic opening tool to remove the 4 buttons on each corner of the Sidekick.
Gently pry open button and remove button.
Do this for each of the 3 buttons remaining.
Flip the screen up halfway (90 degrees), to reveal the 2 screws above the right side of the keyboard.
Use the Torx 6 screwdriver to remove these 2 screws.
Be careful in handling the phone after removing the screws, because the two main bodies of the phone are no longer attached.
After removing the 6 screws and both bumpers, the phone will be easy to separate into the two main bodies.
You can use your hands to simply pull apart the top casing from the bottom casing.
Remove 4 screws from front of screen with Phillip screwdrivers.
Peel off the metal covering on the back of the screen.
Be careful when taking off the metal covering. The orange ribbon will not come out all the way, and it is fragile.
Remove the protective cover in front of the screen.
Do not use metal tools, you may damage the protective cover or the screen. Use your fingers only.
Remove the 5 black screws with a Phillips head screwdriver.
Lift the bottom of the control board from housing, and separate the two.
Carefully remove battery and back plate.
Do not use metal tools, you may damage the control board. Use only your fingers.
Incorpora questa guida
Scegli una dimensione e copia il codice qui sotto per incorporare questa guida come un piccolo widget sul tuo sito/forum.
Anteprima
