Salta al contenuto principale
Cosa ti serve
Questo smontaggio non è una guida di riparazione. Per riparare il tuo Scrabble Flash, usa il nostro manuale di assistenza.
  1. Scrabble Flash Teardown, Scrabble Flash Teardown: passo 1, immagine 1 di 2 Scrabble Flash Teardown, Scrabble Flash Teardown: passo 1, immagine 2 di 2
    • This is a small game but still surprisingly fun... but not enough to keep me from tearing it down!
  2. Scrabble Flash Teardown, Remove the Back: passo 2, immagine 1 di 1
    • This was held together by only one Phillips screw. So far so good.
    • Battery was a CR2032, which seems to be a common choice for this type/size of device
    • The speaker is in the bottom-right hand corner, with the reset switch above it.
  3. Scrabble Flash Teardown: passo 3, immagine 1 di 1
    • Two screws and a clip held the two halves of the case together, with two more keeping the speaker in place. Also, it looks like the only screws used in this device are Phillips! Great!
  4. Scrabble Flash Teardown, On to the Motherboard: passo 4, immagine 1 di 2 Scrabble Flash Teardown, On to the Motherboard: passo 4, immagine 2 di 2
    • On the back side of the motherboard, we see the battery contacts in the upper-left hand corner, and the four screws that hold the display to the front.
  5. Scrabble Flash Teardown, Display Removal: passo 5, immagine 1 di 3 Scrabble Flash Teardown, Display Removal: passo 5, immagine 2 di 3 Scrabble Flash Teardown, Display Removal: passo 5, immagine 3 di 3
    • After removing three of the screws, I found that the one holding down the bottom-left corner of the display was stripped, forcing me to cut and rotate the corner away.
    • After that however, it just dropped right off.
    • The display is just a simple black and white LCD.
  6. Scrabble Flash Teardown, Done!: passo 6, immagine 1 di 1
    • And here we are, all done!
Isaiah Payton
Membro da: 12/29/16
133 Reputazione
1 Guida realizzata
2 Commenti
Very cool, great teardown!!
Kevin Stuckey - Replica
Mine has a broken infrared thingy. Any idea how to/if it's fixable? I hope someone reads this :s
Yemir 2 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 22
Tutti i Tempi: 2,011
