Salta al contenuto principale
Cosa ti serve
Questo smontaggio non è una guida di riparazione. Per riparare il tuo Scotch TL901, usa il nostro manuale di assistenza.
  1. Scotch TL901 Teardown, The Laminator: passo 1, immagine 1 di 1
    • The Scotch TL901 Laminator
  2. Scotch TL901 Teardown, Unscrewing the Case: passo 2, immagine 1 di 1
    • Using a small Phillips screwdriver, remove the screws from the bottom of the plastic case.
    • Rubber feet in the four corners must be removed first to gain access to the screws underneath. A sticker may also be covering the middle screw on the left.
  3. Scotch TL901 Teardown, The Opened Laminator: passo 3, immagine 1 di 1
    • Pull off the silver plastic cover and gain access to the internal components.
    • The rollers, motor, circuit board, and LEDs are all visible now.
  4. Scotch TL901 Teardown, The Circuit Board: passo 4, immagine 1 di 1
    • First unplug all three wire headers connected to the circuit board.
    • Unscrew the two screws holding down the circuit board by its corners and remove the board from the laminator.
  5. Scotch TL901 Teardown, The Spring: passo 5, immagine 1 di 1
    • Unhook the spring from the plastic surrounding the motor.
  6. Scotch TL901 Teardown, The Rollers: passo 6, immagine 1 di 1
    • Hold the roller enclosure from both sides, indicated by the markers, and pull upwards and slightly out.
    • Free access to the motor and rollers is now possible.
  7. Scotch TL901 Teardown, The Motor: passo 7, immagine 1 di 1
    • Remove the motor from the rollers by unscrewing the three screws holding them together.
  8. Scotch TL901 Teardown, The Sensor: passo 8, immagine 1 di 1
    • Remove the sensor from the roller enclosure by unscrewing the two spring-loaded screws.
  9. Scotch TL901 Teardown, The Other Side: passo 9, immagine 1 di 1
    • Unscrew the two screws and the bar on the other.
  10. Scotch TL901 Teardown, The Gears: passo 10, immagine 1 di 1
    • Pull the black washers sideways off the metal rod of the roller.
    • Pull the gears off.
  11. Scotch TL901 Teardown, The Disassembled Rollers: passo 11, immagine 1 di 2 Scotch TL901 Teardown, The Disassembled Rollers: passo 11, immagine 2 di 2
    • With the gears off, the plastic panel falls off and the rollers come out of the enclosure.
    • The laminator is now disassembled.
Calvin Xu
Membro da: 04/18/13
202 Reputazione
1 Guida realizzata
F14BraunReverseEng Membro di F14BraunReverseEng
Community
2 Membri
8 Guide realizzate
16 Commenti
Why is the screw on the left side so hard to get out?
Teri L Geist - Replica
Thank you..
Putting it back together is more of a challenge.
Frank - Replica
You're right Frank. For me, getting it to stay together after the tear down and reassembly required superglue and two extra screws. ;) But at least it's working again. Thanks for the great instructions.
pjcall975 - Replica
Thank you! Just needed to open and remove a jam. Followed your guide and all is well.
KQuinn
Kate Quinn - Replica
Thank you for posting these instructions. I was able to remove a quarter that got trapped inside.
seanretzloff - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 37
Ultimi 30 Giorni: 131
Tutti i Tempi: 29,281
