Strumenti necessari in questo Smontaggio
Introduzione
We disassembled this calculator on April 17, 2010.
Questo smontaggio non è una guida di riparazione. Per riparare il tuo Sanyo CX 110, usa il nostro manuale di assistenza.
    • Here is the Sanyo CX 110 calculator.
    • Remove these two screws from the back of the calculator using a Phillips #0 Screwdriver.
  1. Now that we removed the back of the calculator, here is the battery and the back of the logic board. Sanyo Tight-Seal Power-Up Sum-3 1.5V AA battery.
    • Now that we removed the back of the calculator, here is the battery and the back of the logic board.
    • Sanyo Tight-Seal Power-Up Sum-3 1.5V AA battery.
    • Positive contact for the battery.
    • Negative contact for the battery.
  2. Spedizione gratuita per tutti gli ordini superiori a 100 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  3. Remove these 7 screws using a razor blade.
    • Remove these 7 screws using a razor blade.
    • Be careful not to break the razor blade because it is fragile.
    • Turn the circuit board 180 degrees after removing screws.
  4. You will now see the circuit board and the buttons. Remove the buttons for the calculator. You will now see the circuit board and the buttons. Remove the buttons for the calculator.
    • You will now see the circuit board and the buttons. Remove the buttons for the calculator.
  5. Now we're all done! Just take the LCD apart and you are done completely!
    • Now we're all done! Just take the LCD apart and you are done completely!
    • Sum-3 Sanyo Battery.
    • LCD Screen Parts (darkener, inverter, LCD screen.
    • Circuit Board for the calculator.
    • Buttons for the calculator (square root, memory, percent, operators, numbers, etc.)
    • Housing for the calculator.
samhnri
Membro da: 07/04/2010
417 Reputazione
2 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 11
Tutti i Tempi: 4,890
