Questo smontaggio non è una guida di riparazione. Per riparare il tuo Samsung Galaxy Ace, usa il nostro manuale di assistenza.
With a plastic tool separate the frame from the aluminum plate. (either from the inside or outside)
Make sure your Micro SD card is removed from the device Micro SD card slot.
Disconnect the microphone using your fingers, be careful not to do too much pressure.
Disconnect the light sensor and ear piece speaker.To remove this use a plastic tool.
Disconnect the volume rocker, be very careful! They are very thin and glued with double-sided tape. If possible, use isesamo or something really thin!
Lift the logic board from the right side, be careful not cause any damage to gently rotate the LCD connector.
Now with a plastic tool you can disconnect the LCD connector.
Use a plastic tool or something sharp to lift the aluminum protection that serves to fix earpiece speaker and light sensor and remove it.
After lifting the connector of the touch screen (black tab), lift the cable carefully!
Press the home button to remove it. (This is not fixed,no material).
Heat the glass lens with a hot air gun, a tool insert after "isesamo" and slowly raise it.
Remove it.
Incorpora questa guida
Scegli una dimensione e copia il codice qui sotto per incorporare questa guida come un piccolo widget sul tuo sito/forum.
Anteprima
