Salta al contenuto principale
Cosa ti serve
Questo smontaggio non è una guida di riparazione. Per riparare il tuo Samsung Android Phone, usa il nostro manuale di assistenza.
  1. Samsung AMOLED Display Teardown, Samsung AMOLED Display Teardown: passo 1, immagine 1 di 2 Samsung AMOLED Display Teardown, Samsung AMOLED Display Teardown: passo 1, immagine 2 di 2
    • Here it is: The beautiful fortress of pixels known as the Super AMOLED screen.
    • Now, We take to separating it.
  2. Samsung AMOLED Display Teardown: passo 2, immagine 1 di 1
    • After separating it, we take a closer look at it's insides.
    • The interesting thing is that after we separated it, the screen worked (no black spots or lines) but the touch didn't. This is interesting, because the touch and the pixels are integrated into the same layer. We will try to find out why.
    • It looks like the touch has a separate cable than the screen. This is interesting, because the touch and the pixels are integrated into the same layer, as said above. Note the touch screen controller chip in red.
    • Taking a closer look, it appears that we have cut the touch cable while tediously separating the screen. The adhesive securing the display is no joke.
  3. Samsung AMOLED Display Teardown: passo 3, immagine 1 di 1
    • Full IC Identification:
    • You may need to enlarge it to view the text.
  4. Samsung AMOLED Display Teardown: passo 4, immagine 1 di 2 Samsung AMOLED Display Teardown: passo 4, immagine 2 di 2
    • Using a freezer, we separate the AMOLED display from the glass.
    • We take the screen polarizer film off, and we find out that the screen is really a silver-ish color, not black!
    • However, you technically won't be able to see any text or images on the screen without the black polarizer film.
    • We will update you on our later findings on the inside this screen.
Everything iPod Membro di Everything iPod
Community
63 Membri
3 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 93
Tutti i Tempi: 5,551
