Salta al contenuto principale
Questo smontaggio non è una guida di riparazione. Per riparare il tuo Rapoo E6700 Bluetooth Touch Keyboard, usa il nostro manuale di assistenza.
  1. Rapoo E6700 Bluetooth Touch Keyboard Teardown, Rapoo E6700 Bluetooth Touch Keyboard Teardown: passo 1, immagine 1 di 2 Rapoo E6700 Bluetooth Touch Keyboard Teardown, Rapoo E6700 Bluetooth Touch Keyboard Teardown: passo 1, immagine 2 di 2
    • A broken off micro-USB connector for charging a bluetooth keyboard doesn´t seem like a challenge. But wait until you´ve tried with this one: Rapoo E6700 bluetooth keyboard.
  2. Rapoo E6700 Bluetooth Touch Keyboard Teardown: passo 2, immagine 1 di 1
    • I tried to get access to the damaged USB connector, but the bottom cover that contains the main PCB is held in place by screws not from the outside but the inside.
    • So I broke off the bottom cover to repair the connector, but then you cannot connect back the flex connectors to the keyboard.
    • Maby we can separate the keyboard from the aluminium housing ?
  3. Rapoo E6700 Bluetooth Touch Keyboard Teardown: passo 3, immagine 1 di 2 Rapoo E6700 Bluetooth Touch Keyboard Teardown: passo 3, immagine 2 di 2
    • Well for those who try to get the keyboard off, someone has developed superglue.
    • Yes you heard it, not just sticky double sided tape, also superglue applied in the marked areas.
  4. Rapoo E6700 Bluetooth Touch Keyboard Teardown: passo 4, immagine 1 di 2 Rapoo E6700 Bluetooth Touch Keyboard Teardown: passo 4, immagine 2 di 2
    • Here´s the keyboard after 1 hour trying to separate the parts.
    • And another view of the superglue residuals on the keyboard side.
  5. Rapoo E6700 Bluetooth Touch Keyboard Teardown: passo 5, immagine 1 di 2 Rapoo E6700 Bluetooth Touch Keyboard Teardown: passo 5, immagine 2 di 2
    • This is the 'repaired' keyboard
    • and the only reason to repair: the broken off (badly soldered) USB connector.
    • What a waste of materials
Thomas Widmaier
Membro da: 03/05/13
2.039 Reputazione
10 Guide realizzate
Master Techs Membro di Master Techs
Community
322 Membri
2.519 Guide realizzate
13 Commenti
I just could say yes to that,
I obtained two of thes key boards, where I broke off, two connectors, qhat a &&^&@@ up piece of sh**
couldn´t handle to open it up, dropped the keys-buttons and so on, really crap like board...
Cheers
darkheart - Replica
Thomas, thx for publishing your findings - I was just about to start trying to figure out how to open it to repair the USB connector (so I can charge it), but I think I will save my time and go buy a different one. It's sad that such a nice looking/working keyboard is so unusable because of a simple broken off USB connector...
Bunia Yakkazuzzi - Replica
... the bottom cover of the keyboard can be opened with a screwdriver.
piecemeal unclamp the sides and you can then access the USB port easyly without further damage...
see:
[IMG]http://i68.tinypic.com/bi9fus.jpg[/IMG]
und
[IMG]http://i65.tinypic.com/2mdjbkm.jpg[/IMG]
If a few scratches on the aluminum do not bother
sicz - Replica
Hi, there are 6 screws and 2 clips holding the cover over the main circuit pcb. You can lever the cover away from the main part of the keyboard and break the supports for the screws and probably break at least one of the clips. OR you could try drilling out the screws and save the clips. You will need to be accurate with the drilling or you will damage the wires to the battery possibly causing FIRE! Alternately leave these two for breaking off. You can effect required repairs and refix the pcb and cover to the main part of the keyboard with double sided tape or your preferred alternative.
One other hint, when replacing the striplines connect the trackpad (small) one first as the larger one is much easier to fit second than the other way around.
Do not attempt to open the keyboard from the top as super glue and disaster lurk on that path.
Gary Richter - Replica
The positions to drill mentioned in my last post follow:
8mm towards the front of the keyboard from the centre of each of the small round feet.
Draw a line connecting these two holes. Measure 60mm and a further 105mm from the hole nearest the on/off switch and 8mm forward and back at each of these points.
Try a 1-2mm drill so you can see where the screw is before drilling a bigger hole. The support that the screws screw into is 3mm in diameter so if you use a 3mm (1/8inch) drill you should disconnect the support from the cover. all that will be left is a rib running front to back.
Take this slowly.
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 19
Tutti i Tempi: 8,053
