Strumenti necessari in questo Smontaggio
Introduzione
Going to take apart my Power Mac 8600/250!
Tools:
#1 Phillips screwdriver
Spudger/Flathead screwdriver
Your hands!
Questo smontaggio non è una guida di riparazione. Per riparare il tuo Power Macintosh 8600(250), usa il nostro manuale di assistenza.
There she is! i'm missing the bezel around the floppy drive :(
  • There she is! i'm missing the bezel around the floppy drive :(
Aggiungi Commento
Start by pressing the big green button. And pulling the door away and up from the computer.
  • Start by pressing the big green button. And pulling the door away and up from the computer.
  • And on the Back of the door is the fan.
Aggiungi Commento
  • Now it's best to lay the computer flat.
  • And to flip up the tabs, grab the handle and open.
Aggiungi Commento
  • The innards, motherboard, daughter board, RAM and so fourth.
Aggiungi Commento
  • Now the speaker
  • Remove the speaker wires
  • And the fan wires from the motherboard
  • Push in the two plastic tabs on either side and lift the speaker up and out.
Aggiungi Commento
  • The PRAM battery!
  • Remove the housing by pulling it out and then take the battery out.
Aggiungi Commento
  • The processor, firmly grasp and pull out.
  • Remove the 4 #1 Phillips screws
  • And push the 4 tabs off of the board
High failure rate - these bassas’
Mal - Replica
  • Any video card or usb card, mine happens to be an ethernet 10/100 card.
  • Unfortunately there are 6 spaces but only 3 slots on the motherboard :(
  • Remove the #1 Phillips screw and pull the card out.
Aggiungi Commento
  • RAM and VRAM slots!
Aggiungi Commento
  • Moving on to the CD, ZIP, and Floppy drives (best to close computer now)
  • Remove the bezels and if I had the top one remove that too.
  • Remove the 6 phillips screws and pull the metal frames out.
Aggiungi Commento
  • Remove the data and power cables
  • Pay special attention to this one, it has a clip on it, it helps to use a flathead or a spudger.
  • Pull the drives out of the bay.
Aggiungi Commento
  • Now the hard drive.
  • Remove the two phillips screws
  • And the data and power cables (might help to remove them as you pull the drive out)
Aggiungi Commento
  • The power source
  • Remove the two connectors
  • There is a clip holding the wires in place. Separate and remove the wires. (both sets)
Aggiungi Commento
  • Now remove the 4 phillips screws (it's best to start with the bottom two)
  • And pull it out while de-threading the wires.
Aggiungi Commento
Plague
Membro da: 14/06/2010
161 Reputazione
1 Guida realizzata
Nice. I got a beige G3 300 Mhz, the case is similar. Maybe I could also make a teardown.
Nicolas Zbinden - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 18
Tutti i Tempi: 13,222
