Strumenti necessari in questo Smontaggio
Introduzione
The Infamous Powermac G4 Cube, Apple's original failed attempt at a compact G4-Based Macintosh. Released in 2000 at a cost of $1599, the cube was considered too expensive, and too slow. The Cube Unlike many other computer's uses passive cooling, where there is no fan. This was a big mistake on apple's part, because G4 processors run very hot!
The Cube boasted a 450MHz or 500Mhz G4 CPU; not very fast. Back then, they had 1Ghz Pentium III's. The cube is virtually silent, except for the original 5400 RPM hard drives. After one year of production, Apple put the cube "On Ice." The Cube is also a popular candidate for macquariums. It also has an internal fan hookup, but it isn't used by Apple. If you want, you can buy a fan, and connect it to the 12V 2-Pin connector, and find somewhere to put it in the cube; this is a popular mod to cool overheating cubes.
It was replaced by the Mac Mini in 2005, 5 years later. At a later time, I will re-post this as a repair guide.
Removing the Ram
Start by fliping the cube so that the side with the graphics card is facing you, you may want to push the handle back in.
There are 3 RAM Slots, they are Standard PC100 Ram. The cube can support up to 1.5GB of ram, that's a 512MB Stick In All 3 Slots.
Remove the ram, just like any other kind of ram.
Removing the AGP Riser card
Pull the card out of the PCI Socket, and no, unfortunately, you can't use this to put an AGP card in a PCI slot in a PC.
Once the card is free, mind the 3 cables attached to it, remove these 2 cables first.
The third cable is glued to the AGP board, unplug it from the logic board instead.
Removing the Voltage Regulator Module.
This board is called the DC/DC board, or the Voltage Regulator Module. It takes the power from the power brick and regulates the power to different components of the Cube.
First, disconnect the power connector.
Then release the white clip on the connector socket, which is accessed from the side of the core.
With a little persuasion, the board comes out of it's socket(it's hard to show how the board comes out, but in person, it's pretty self explanatory)
The Logic Board
Unfortunately, this as far as I am going to dissect my cube, partially because I still use it frequently, but here is an overview of the cube.
450Mhz or 500Mhz PowerPC G4 Processor
Shipped with 64MB ram, supports up to 1.5GB of PC100 or PC133
One PCI Slot(Converted to AGP via adaptor)
No Onboard Audio.(Unfortunately)
6 Commenti
This is great! What a beautiful machine that was.
Awesome teardown, Chris! Thanks for posting it.
Worst pictures I've seen in a teardown in a long time…
