Salta al contenuto principale
Introduzione
PlayStation 3 super slim - how to fully disassemble.
You can see also: PlayStation 3 Super Slim Teardown
Please SUBSCRIBE to my channel ツ
Panoramica Video
  1. Remove the three rubber feet, warranty sticker and four screws. Gently pull up on the bottom cover to remove it. Gently pull up on the bottom cover to remove it.
    • Remove the three rubber feet, warranty sticker and four screws.
    • Gently pull up on the bottom cover to remove it.
  2. Slide the HDD cover toward the rear of the device to remove it. Remove the blue screw shown to remove the HDD caddy. Remove the blue screw shown to remove the HDD caddy.
    • Slide the HDD cover toward the rear of the device to remove it.
    • Remove the blue screw shown to remove the HDD caddy.
  3. Use a metal spudger to push the tab on the rear top finisher, and lift up to remove it. Use a metal spudger to push the tab on the rear top finisher, and lift up to remove it. Use a metal spudger to push the tab on the rear top finisher, and lift up to remove it.
    • Use a metal spudger to push the tab on the rear top finisher, and lift up to remove it.
  4. Repeat step 3 for the front top finisher. Repeat step 3 for the front top finisher. Repeat step 3 for the front top finisher.
    • Repeat step 3 for the front top finisher.
  5. Kit riparazione batterie MacBook
    A partire da $69.99
    Buy Now
    A partire da $69.99
    Buy Now
  6. Remove the two screws indicated in the disk reader. Remove the five screws shown around the edge of the top cover. Lift the top cover up to remove it.
    • Remove the two screws indicated in the disk reader.
    • Remove the five screws shown around the edge of the top cover.
    • Lift the top cover up to remove it.
  7. Move the optical disk reader assembly to the left to expose one of the screws holding the power supply in. Remove the two screws indicated and carefully disconnect the cable on the right side of the power supply. Lift the power supply up to remove it.
    • Move the optical disk reader assembly to the left to expose one of the screws holding the power supply in.
    • Remove the two screws indicated and carefully disconnect the cable on the right side of the power supply.
    • Lift the power supply up to remove it.
  8. Carefully disconnect the ribbon cables indicated. Lift the optical disk reader up to remove it. Disconnect and remove the white cable and ribbon cable indicated.
    • Carefully disconnect the ribbon cables indicated.
    • Lift the optical disk reader up to remove it.
    • Disconnect and remove the white cable and ribbon cable indicated.
  9. Remove the seven screws indicated. Lift the motherboard assembly up out of the lower half of the case to remove it. Carefully disconnect the Wi-Fi antenna cables and fan connector indicated by  red arrows.
    • Remove the seven screws indicated.
    • Lift the motherboard assembly up out of the lower half of the case to remove it.
    • Carefully disconnect the Wi-Fi antenna cables and fan connector indicated by red arrows.
  10. Remove the six screws indicated to separate the heatsink and shield from the motherboard. Remove the six screws indicated to separate the heatsink and shield from the motherboard. Remove the six screws indicated to separate the heatsink and shield from the motherboard.
    • Remove the six screws indicated to separate the heatsink and shield from the motherboard.
  11. Did you do it successfully?
Conclusione
Altre 21 persone hanno completato questa guida.
ZFix
Membro da: 09/12/2013
164.077 Reputazione
305 Guide realizzate
Master Techs Membro di Master Techs
Community
286 Membri
808 Guide realizzate
What's the name of the screwdriver that undo's the star shaped screws?
themasterassassin8787 - Replica
It is a T8 Torx screwdriver! I'll add the tools to this guide =)
Sam Lionheart -
i took apart my ps3 super slim and put it back together but there is no power what so ever no red light at all
pastorjon.m - Replica
Same here did you fix it?
Kriss -
One thing to pay attention to: The T8 Torx screws (at least on my 500GB model) are Tamper Proof TR8 screws, meaning you need a special screwdriver to undo them. A normal T8 wont work.
Wesley V - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 22
Ultimi 7 Giorni: 97
Ultimi 30 Giorni: 475
Tutti i Tempi: 33,579
