Smontaggio
Questo smontaggio non è una guida di riparazione. Per riparare il tuo Pentax Optio WG-1 GPS, usa il nostro manuale di assistenza.
Clean the device. You are able to rinse with under running water. It is recommended to ensure that you remove the battery and memory card before working with the device.
Prepare a clean workstation and have your tool(s) ready.
Remove 4 Phillips 1/4 inch 00 screws around the border of the display with the screwdriver.
Remove the black rubber adhesive around the border of the device by peeling slowly.
Remove 2 Phillips 00 1/4 inch rubber sealed screws off the top of the camera.
Remove the display screen from the casing. When opening, the micro USB cover and the battery cover will fall out with a pin.
Remove all orange strips located on the motherboard and the LCD screen.
Lift black latches before removing the strips.
Remove the lens from the camera carefully. It is the black block held inside the casing.
Remove 3 Phillips 00 screws from the motherboard.
Remove 2 Phillips 00 screws from the mini USB bay.
Remove 2 Phillips 00 screws from the silver handle on the side of the camera.
Remove 3 Phillips 00 screws from the camera's photo capture button.
After removing those screws, remove the plastic piece and buttons they secure.
Remove 3 Phillips 00 screws from the same location located under the cameras photo capture button.
Remove the motherboard from the housing.
con 4 altri collaboratori
Membro da: 01/27/15
122 Reputazione
1 Guida realizzata
Distintivi: 3
PHSC-PRINCE-W15S1G3
6 Membri
Scegli una dimensione e copia il codice qui sotto per incorporare questa guida come un piccolo widget sul tuo sito/forum.
Ultime 24 Ore: 2
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 21
Tutti i Tempi: 3,139
