Salta al contenuto principale
Cosa ti serve
Questo smontaggio non è una guida di riparazione. Per riparare il tuo Panasonic RZ-S50W (Japan) Bluetooth Headphones, usa il nostro manuale di assistenza.
  1. Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown, Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: passo 1, immagine 1 di 3 Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown, Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: passo 1, immagine 2 di 3 Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown, Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: passo 1, immagine 3 di 3
    • Features:
    • Exceptional Sound and Noise Cancellation. Multiple MEMS microphones
    • Optimum Sound Isolation
    • Strong, Stable Connection
    • High-Quality Calling Sound
    • Approximately, 6 hours playback, and up to 20 Hours of use with charger
    • Bluetooth® 5.0
    • Capacitive touch sensor control
  2. Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: passo 2, immagine 1 di 3 Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: passo 2, immagine 2 di 3 Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: passo 2, immagine 3 di 3
    • What is in the box
    • Headphones / Charging Case
    • USB 'C' Cable
    • Headphone rubber tips for different sizes of ears
    • User's Manual
  3. Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: passo 3, immagine 1 di 3 Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: passo 3, immagine 2 di 3 Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: passo 3, immagine 3 di 3
    • Charging case with headphones
    • Close up view of headphones
  4. Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: passo 4, immagine 1 di 3 Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: passo 4, immagine 2 di 3 Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: passo 4, immagine 3 di 3
    • Side views of Headphone
    • MEMS Microphones
    • Speaker Spatial Vent Port
    • Speaker Sound Port
    • Speaker Vent
    • USB Interface
    • Charger Interface
    • Vent Port
  5. Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: passo 5, immagine 1 di 1
    • View of Headphone with rubber ear piece [cap] removed
    • Vent Port
  6. Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: passo 6, immagine 1 di 3 Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: passo 6, immagine 2 di 3 Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: passo 6, immagine 3 di 3
    • Since the Panasonic Headphone enclosure is glued together, the only way in was to cut into the headphone.
    • This is a destructive teardown
    • A Razsor Knife was use to cut into the Panasonic headphone along the seam in the headphone. Then a Jimmy Tool was used to open up the headphone
    • Once opened, we get our first look at the inside of the headphone
  7. Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: passo 7, immagine 1 di 3 Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: passo 7, immagine 2 di 3 Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: passo 7, immagine 3 di 3
    • Opening up the headphone, we can see the main PCB, Battery, Speaker, etc. Tweezers and a Pick Tool were used to removed the electronics from the enclosure
    • Double sided foam tape was used to hold the main the PCB to the Battery and to the Touch Sensor / Antenna PCB. This foam tape had to be cut free. Then Denatured Alcohol was used to remove the foam tape glue from the PCBs and Battery
    • Battery
    • Main PCB
    • Speaker Area
    • Touch Sensor and Antenna
    • Double Sided Foam Tape
  8. Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: passo 8, immagine 1 di 3 Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: passo 8, immagine 2 di 3 Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: passo 8, immagine 3 di 3
    • At first, I wasn't sure about the solder balls. Then I realized they are used to anchor the USB and Power Interface pins on the outside of the Headphone to the internal circuit board.
    • I had to used a soldering iron to remove the solder balls, so that the internal interface circuit board could be removed. I had to also remove solder from the speaker wires to free up the internal circuit board.
    • The internal circuit board was also attached a MEMS Microphone that appeared to be monitoring the Speaker Chamber of the Headphone, since it was faced in. I had to remove the outside panel with 'R' on it with a Razor Knife to free the MEMS Microphone. Once the MEMS Microphone was freed, the interface circuit board could be pulled out
    • USB and Power (Charger) Interface
    • MEMS Microphone
    • Sound Ports
    • Speaker Wires
    • Internal Circuit Board that interface Power and USB to the Headphones
  9. Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: passo 9, immagine 1 di 3 Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: passo 9, immagine 2 di 3 Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: passo 9, immagine 3 di 3
    • There was not much to see on the internal interface board. The was one IC component that could not be crossed. If you happen to know the component, please leave a comment below
    • Unknown Component
  10. Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: passo 10, immagine 1 di 2 Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: passo 10, immagine 2 di 2
    • Full Sensor Flex/Charging PCB IC Identification:
    • You may need to enlarge the picture to view the text.
  11. Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: passo 11, immagine 1 di 3 Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: passo 11, immagine 2 di 3 Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: passo 11, immagine 3 di 3
    • Next the Speaker sound chamber cover was removed with the use of a Pick Tool and Tweezers. A Razor Knife was used to cut the glue holding the speak in place
    • The speaker had no identifiable markings
    • With Speaker removed, we can see the sound chamber and sound ports
  12. Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: passo 12, immagine 1 di 2 Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: passo 12, immagine 2 di 2
  13. Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: passo 13, immagine 1 di 2 Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: passo 13, immagine 2 di 2
    • Closeup view of the Antenna/Touch Sensor side of the Main PCB
    • DSP Group - C2A1A Hybrid Active Noise Cancellation (ANC) Codec and Audio Digital Signal Processor (DSP)
    • 651DF1M9 - Could not cross part number, but during a web search found out that it may be an integrated battery management IC
    • W25Q32JWUUIMTR- SPI FLASH 32Mb
    • MEMS Microphone Port
  14. Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: passo 14, immagine 1 di 3 Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: passo 14, immagine 2 di 3 Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: passo 14, immagine 3 di 3
    • Closeup view of some of the components on the Antenna/Touch Sensor side of the Main PCB
  15. Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: passo 15, immagine 1 di 2 Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: passo 15, immagine 2 di 2
    • Battery side close up view of the Main PCB
    • AIROHA AB1552 - ARM Cortex M4/Bluetooth 5.0 Dual Mode
    • 927 MPS1 MEMS Microphone. The Headphone uses three MEMS microphones with this part number
    • Could not cross the part number. If you know the part, please leave a comment below. The 2D bar code on the part reads as STM927352NH2S011
    • Crystal Oscillator
    • Unknown component. Labelled B2A. Please leave a comment if you happen to know this component
    • Unknown component. Labelled SV4CP 240. Please leave a comment if you happen to know this component. Separated from PCB during teardown
  16. Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: passo 16, immagine 1 di 3 Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: passo 16, immagine 2 di 3 Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: passo 16, immagine 3 di 3
    • Closeup view of some of the components on the Battery side of the Main PCB
    • 927 MPS1 MEMS Microphone. The Headphone uses three of these MEMS microphones
    • Unknown component. Labelled B2A. Please leave a comment if you happen to know this componentNew line.
  17. Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: passo 17, immagine 1 di 2 Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: passo 17, immagine 2 di 2
    • Closeup view of top and bottom side of the Touch Sensor Flex PCB and PCB Antenna
  18. Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: passo 18, immagine 1 di 2 Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: passo 18, immagine 2 di 2
    • Full Main PCB IC Identification:
  19. Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: passo 19, immagine 1 di 1
    • Predicted Block Diagram of the Panasonic RZ-S50W Bluetooth Headphones:
  20. Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: passo 20, immagine 1 di 2 Panasonic RZ-S50W (Japan) Bluetooth Headphones Teardown: passo 20, immagine 2 di 2
    • Teardown Exploded View of the Panasonic Headphone
Robert Shuler
Membro da: 03/12/19
3.549 Reputazione
11 Guide realizzate
3 Commenti
If you can, can you post the teardown of the charging case too?
CChin - Replica
Dong a web search, I believe the glue removed from the speaker was a silicone dome used to help compress sound waves?
Moe Moe's - Replica
yes second the charging case!
Benjamin - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 50
Tutti i Tempi: 2,382
