Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Strumenti necessari in questo Smontaggio
Questo smontaggio non è una guida di riparazione. Per riparare il tuo Panasonic AG-1300, usa il nostro manuale di assistenza.
  1. The only tool needed is a medium sized  screw driver
    • The only tool needed is a medium sized screw driver
  2. The first step is to unscrew both screws on both sides of the VCR The first step is to unscrew both screws on both sides of the VCR The first step is to unscrew both screws on both sides of the VCR
    • The first step is to unscrew both screws on both sides of the VCR
  3. After removing the cover you must unclip all the clips of the front paneling After removing the cover you must unclip all the clips of the front paneling After removing the cover you must unclip all the clips of the front paneling
    • After removing the cover you must unclip all the clips of the front paneling
  4. Remove this metal  plate by unclipping the clips on its sides. Remove this metal  plate by unclipping the clips on its sides. Remove this metal  plate by unclipping the clips on its sides.
    • Remove this metal plate by unclipping the clips on its sides.
  5. Unscrew all of these screws to remove the main plate Unscrew all of these screws to remove the main plate Unscrew all of these screws to remove the main plate
    • Unscrew all of these screws to remove the main plate
  6. before removing the plate disconnect these three wires to preserve the functions of the VCR. before removing the plate disconnect these three wires to preserve the functions of the VCR. before removing the plate disconnect these three wires to preserve the functions of the VCR.
    • before removing the plate disconnect these three wires to preserve the functions of the VCR.
  7. Remove this one screw
    • Remove this one screw
  8. Remove the main plate and then flip it over to reveal the motor Now unscrew all of these screws and there you go you just tore down a VCR to its major components And now all your major components should be spread out like this
    • Remove the main plate and then flip it over to reveal the motor
    • Now unscrew all of these screws and there you go you just tore down a VCR to its major components
    • And now all your major components should be spread out like this
Herson Calderon
Membro da: 20/04/2018
157 Reputazione
1 Guida realizzata
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 354
