Strumenti necessari in questo Smontaggio
Questo smontaggio non è una guida di riparazione. Per riparare il tuo Nokia 2605, usa il nostro manuale di assistenza.
  1. Red arrows indicate which screws must be removed in order to get to the motherboard.
    • Red arrows indicate which screws must be removed in order to get to the motherboard.
  2. Take T5 torx and remove all 3 screws.
    • Take T5 torx and remove all 3 screws.
  3. Spedizione gratuita per tutti gli ordini superiori a 100 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  4. Wedge a flat head in between the back and phone exterior starting at the bottom corners.
    • Wedge a flat head in between the back and phone exterior starting at the bottom corners.
    • As you move toward the top, remove the camera and volume buttons.
  5. Remove the back, being careful not to detach the motherboard from the back and to not pull them fully out (both attached at the upper left corner by a black strip). Remove the back, being careful not to detach the motherboard from the back and to not pull them fully out (both attached at the upper left corner by a black strip).
    • Remove the back, being careful not to detach the motherboard from the back and to not pull them fully out (both attached at the upper left corner by a black strip).
Dorsa
Membro da: 07/11/2013
143 Reputazione
1 Guida realizzata
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,023
