Salta al contenuto principale
Cosa ti serve
Questo smontaggio non è una guida di riparazione. Per riparare il tuo Motorola California Mobile Phone, usa il nostro manuale di assistenza.
  1. Motorola California Mobile Phone Teardown, Motorola California Mobile Phone Teardown: passo 1, immagine 1 di 1
    • Remove the battery by sliding it down the rails to which it is connected.
  2. Motorola California Mobile Phone Teardown: passo 2, immagine 1 di 1
    • Find a flat head or Phillips head screwdriver.
    • Insert the screwdriver into the holes in the plastic rod connecting the key pad guard to the rear casing.
    • Use the screwdriver to push the rods towards each other until they click out of their locked position.
    • Note: This may require a large amount of force.
  3. Motorola California Mobile Phone Teardown: passo 3, immagine 1 di 1
    • Slide off the antenna guard and locate the four clips on the exterior of the rear casing.
    • Simultaneously push the clips outward while lifting the rear casing and keyguard away from the front casing.
    • Remove the key guard from the rear casing by taking it out of its position.
  4. Motorola California Mobile Phone Teardown: passo 4, immagine 1 di 1
    • Locate and unplug the black component of the antenna from the motherboard.
    • Under the black component should be a blue component. Unscrew this component in order to free the antenna.
  5. Motorola California Mobile Phone Teardown: passo 5, immagine 1 di 1
    • Slide the antenna out of the green tubing and slide the green tubing out of it's corresponding hole on the motherboard.
  6. Motorola California Mobile Phone Teardown: passo 6, immagine 1 di 1
    • Lift the motherboard out of its location in the front casing.
    • Do this slowly and gently so that none of the motherboard's components are damaged.
Andrew Lam
Membro da: 04/17/12
35 Reputazione
4 Guide realizzate
Cal Poly, Team 9-46, Regan Spring 2012 Membro di Cal Poly, Team 9-46, Regan Spring 2012
CPSU-REGAN-S12S9G46
5 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 7,583
