Salta al contenuto principale
Cosa ti serve
Questo smontaggio non è una guida di riparazione. Per riparare il tuo Logitech V220 - Cordless Optical Mouse, usa il nostro manuale di assistenza.
  1. Logitech V220 - Cordless Optical Mouse Teardown, Removing the USB Wireless Receiver: passo 1, immagine 1 di 3 Logitech V220 - Cordless Optical Mouse Teardown, Removing the USB Wireless Receiver: passo 1, immagine 2 di 3 Logitech V220 - Cordless Optical Mouse Teardown, Removing the USB Wireless Receiver: passo 1, immagine 3 di 3
    • Wash your hands before replacing the battery to prevent debris getting into the mouse and damaging its internal components.
    • Orient the mouse so you are viewing its base.
    • Using your fingers, gently remove the USB wireless receiver by sliding it towards you.
    • USB removal will result in the power switch to be in its ON position.
    • With your fingertip, engage the power switch to its OFF position to ensure the mouse is not powered.
  2. Logitech V220 - Cordless Optical Mouse Teardown, Removing the Mouse Pads: passo 2, immagine 1 di 3 Logitech V220 - Cordless Optical Mouse Teardown, Removing the Mouse Pads: passo 2, immagine 2 di 3 Logitech V220 - Cordless Optical Mouse Teardown, Removing the Mouse Pads: passo 2, immagine 3 di 3
    • Locate the four mouse pads.
    • Use the rectangular end of the metal spudger to get underneath each mouse pad, pry them up, and peel them off.
  3. Logitech V220 - Cordless Optical Mouse Teardown, Unscrewing the Mouse Housing Screws: passo 3, immagine 1 di 1
    • Locate the four #0 Phillips screws where the mouse pads previously were.
    • Unscrew the four #0 Phillips screws with the Phillips #0 screwdriver.
  4. Logitech V220 - Cordless Optical Mouse Teardown, Separating the Mouse Housing: passo 4, immagine 1 di 2 Logitech V220 - Cordless Optical Mouse Teardown, Separating the Mouse Housing: passo 4, immagine 2 di 2
    • Once the housing screws are fully removed, slowly (and carefully) separate the top and bottom halves of the housing.
    • Rapid separation of the housing halves may result in damaging the power cables (red and black wires) and molex (white plug).
  5. Logitech V220 - Cordless Optical Mouse Teardown, Detaching the Top Mouse Housing: passo 5, immagine 1 di 2 Logitech V220 - Cordless Optical Mouse Teardown, Detaching the Top Mouse Housing: passo 5, immagine 2 di 2
    • Gently set the mouse halves down on a flat surface.
    • Secure the base half with one hand.
    • With thumb and forefinger, grab the end of the molex and pull it away from you until the molex is unplugged.
  6. Logitech V220 - Cordless Optical Mouse Teardown, Removing the Scroll Wheel: passo 6, immagine 1 di 3 Logitech V220 - Cordless Optical Mouse Teardown, Removing the Scroll Wheel: passo 6, immagine 2 di 3 Logitech V220 - Cordless Optical Mouse Teardown, Removing the Scroll Wheel: passo 6, immagine 3 di 3
    • Locate the one, scroll wheel, #0 Phillips screw near the very front edge of the mouse.
    • Turn the mouse 90 degrees clockwise.
    • While supporting the rear of the mouse base, unscrew the #0 Phillips scroll wheel screw.
    • Once the scroll wheel screw is fully removed, manually extract the scroll wheel and spring assembly.
  7. Logitech V220 - Cordless Optical Mouse Teardown, Removing the Scroll Wheel Spring: passo 7, immagine 1 di 2 Logitech V220 - Cordless Optical Mouse Teardown, Removing the Scroll Wheel Spring: passo 7, immagine 2 di 2
    • Locate the scroll wheel spring.
    • Use the tweezers to gently remove the spring by slowly tugging the spring away from the scroll wheel assembly.
  8. Logitech V220 - Cordless Optical Mouse Teardown, Removing the Circuit Board: passo 8, immagine 1 di 3 Logitech V220 - Cordless Optical Mouse Teardown, Removing the Circuit Board: passo 8, immagine 2 di 3 Logitech V220 - Cordless Optical Mouse Teardown, Removing the Circuit Board: passo 8, immagine 3 di 3
    • Locate and remove the circuit board screw.
    • Grip the edges of the circuit board.
    • Manually remove the circuit board from the base of the mold housing.
  9. Logitech V220 - Cordless Optical Mouse Teardown, Removing the Mouse Buttons Screw: passo 9, immagine 1 di 1
    • Locate and remove the #0 Phillips screw in the middle of the mouse.
  10. Logitech V220 - Cordless Optical Mouse Teardown, Removing the Mouse Buttons: passo 10, immagine 1 di 3 Logitech V220 - Cordless Optical Mouse Teardown, Removing the Mouse Buttons: passo 10, immagine 2 di 3 Logitech V220 - Cordless Optical Mouse Teardown, Removing the Mouse Buttons: passo 10, immagine 3 di 3
    • Flip over the top half of the mouse housing so you are viewing underneath it.
    • Locate the mouse button hooks.
    • Rotate the housing 180 degrees clockwise.
    • Using the spudger, firmly push down on each mouse button until the mouse button is released from the hook.
    • Viewing the front of the mouse, the left and right mouse buttons should be detached from the housing.
  11. Logitech V220 - Cordless Optical Mouse Teardown: passo 11, immagine 1 di 1
    • Hold the housing so you are looking down the battery slot.
    • Place the flat end of the spudger between the mouse buttons and the housing.
    • Pry off the mouse buttons.
Tyler Price
Membro da: 04/07/14
1.038 Reputazione
6 Guide realizzate
Cal Poly, Team 6-2, Forte Spring 2014 Membro di Cal Poly, Team 6-2, Forte Spring 2014
CPSU-FORTE-S14S6G2
5 Membri
20 Guide realizzate
Un commento
Tyler - Very good work on this and your other work on this mouse. I appreciate your attention to detail. I wonder if you are the T. Price who used to go to MacDonalds in U/A in 1995? Thanks again so much for your professional work!
Rik Lesel - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 57
Tutti i Tempi: 4,834
