Cosa ti serve
The Linksys WRT-54GL.
Note that the antenna cover is missing but otherwise fully intact.
Note that this is v. 1.1. Other versions may differ slightly.
6 Commenti
thats horrible, why let they post you stuff?
Learn how to make photos and proper documentation OR GET THE &&^& OUT
“This may require considerable force.”
Or, pry out the two front feet, and remove the two hidden screws.
Less effort, less damage.
Steven, which model and revision of router do you have? None of my WRT54GL v1.1 units have screws under the rubber feet, though there are holes to accomodate them. The front comes off without damage. The squeeze and pull did take some force, as I was disengaging two large clips (one on each side of the router.) I think step should be “remove the front rubber feet and remove screws (if present.)” This would help prevent damage and frustration with the great many very similar routers that may have screws.
You broke the right tab on the black part. (It even can be seen in the picture, the semicurcular part that lies on the table.) It will never hold the blue front as it should. Yes, that is the “needs consiserable force”.
I guess all the routers having screws have been broken by their previous owners.
