Salta al contenuto principale
Cosa ti serve
Questo smontaggio non è una guida di riparazione. Per riparare il tuo LG 25UM58-P, usa il nostro manuale di assistenza.
  1. LG 25UM58-P Teardown, Overview: passo 1, immagine 1 di 3 LG 25UM58-P Teardown, Overview: passo 1, immagine 2 di 3 LG 25UM58-P Teardown, Overview: passo 1, immagine 3 di 3
    • Top Tip: If you don't leave an HDMI cable attached to your monitor, you can't trip over it, and destroy your display.
  2. LG 25UM58-P Teardown, Base Removal: passo 2, immagine 1 di 2 LG 25UM58-P Teardown, Base Removal: passo 2, immagine 2 di 2
    • The base plate can be removed by undoing the screw as seen in the second image.
    • Captive D-Ring screw
  3. LG 25UM58-P Teardown, Stand Removal: passo 3, immagine 1 di 3 LG 25UM58-P Teardown, Stand Removal: passo 3, immagine 2 di 3 LG 25UM58-P Teardown, Stand Removal: passo 3, immagine 3 di 3
    • The stand is secrured to the monitor frame with 2 Phillips screws.
    • The small cover needs to be pushed down to disengage the clip.
    • Slide up in order to reveal the screws.
    • 2 x Phillips #1 screws
  4. LG 25UM58-P Teardown, Trim Plate Removal: passo 4, immagine 1 di 2 LG 25UM58-P Teardown, Trim Plate Removal: passo 4, immagine 2 di 2
    • There are 2 Phillips #2 screws holding the lower trim, with the LG logo, onto the monitor.
  5. LG 25UM58-P Teardown, Screen Removal: passo 5, immagine 1 di 3 LG 25UM58-P Teardown, Screen Removal: passo 5, immagine 2 di 3 LG 25UM58-P Teardown, Screen Removal: passo 5, immagine 3 di 3
    • The lower trim piece lifts off with some persuasion.
    • The screen is held on with an overengineered system of clip and tabs. The only method that personally worked, was to pry at the display and lever it out.
    • The guitar picks were used to hold the display panel up and prevent it from clipping back in.
  6. LG 25UM58-P Teardown, More Screen Removal: passo 6, immagine 1 di 2 LG 25UM58-P Teardown, More Screen Removal: passo 6, immagine 2 di 2
    • Once you work your way around the edge of the display, and release all the clips, the panel will be free.
  7. LG 25UM58-P Teardown, Back Cover Removal: passo 7, immagine 1 di 1
    • The rear cover separates from the LCD panel, revealing the surprisingly tiny control board
  8. LG 25UM58-P Teardown, The Clips from Hell: passo 8, immagine 1 di 3 LG 25UM58-P Teardown, The Clips from Hell: passo 8, immagine 2 di 3 LG 25UM58-P Teardown, The Clips from Hell: passo 8, immagine 3 di 3
    • Some close-ups of the clips and mechanism used to secure the rear cover to the LCD panel
  9. LG 25UM58-P Teardown, Part Numbers: passo 9, immagine 1 di 3 LG 25UM58-P Teardown, Part Numbers: passo 9, immagine 2 di 3 LG 25UM58-P Teardown, Part Numbers: passo 9, immagine 3 di 3
    • The panel model appears to be: LM250WW1
    • The LCD itself has the part number: BBSU1V 3467C2
    • The rear housing is stamped with the part number: MCK67880501
  10. LG 25UM58-P Teardown, Mounting Mechanism: passo 10, immagine 1 di 3 LG 25UM58-P Teardown, Mounting Mechanism: passo 10, immagine 2 di 3 LG 25UM58-P Teardown, Mounting Mechanism: passo 10, immagine 3 di 3
    • A closer look at the mounting method shows that there are a series of plastic "rods" that slide into slots on the LCD panel frame. The "rods" then attach to the clips on the rear housing as seen in Step 8.
  11. LG 25UM58-P Teardown, Motherboard: passo 11, immagine 1 di 3 LG 25UM58-P Teardown, Motherboard: passo 11, immagine 2 di 3 LG 25UM58-P Teardown, Motherboard: passo 11, immagine 3 di 3
    • Judging by the markings on the motherboard, it appears that the same PCB is used for the 34UM58.
    • The part number of the board appears to be: 692M000F-002 63624404
  12. LG 25UM58-P Teardown, LCD Hinge Plate Removal: passo 12, immagine 1 di 3 LG 25UM58-P Teardown, LCD Hinge Plate Removal: passo 12, immagine 2 di 3 LG 25UM58-P Teardown, LCD Hinge Plate Removal: passo 12, immagine 3 di 3
    • 4 x #1 Phillips screws are used to secure the hinge plate to the back of the LCD panel.
    • 2 x #2 Phillips screws are used to secure the hinge itself to the LCD panel.
  13. LG 25UM58-P Teardown, Hinge Removal: passo 13, immagine 1 di 2 LG 25UM58-P Teardown, Hinge Removal: passo 13, immagine 2 di 2
    • Carefully route the cables away, from the hinge panel.
    • With the 6 screws removed from the previous step, the hinge assembly can be lifted away.
  14. LG 25UM58-P Teardown, LCD Panel: passo 14, immagine 1 di 3 LG 25UM58-P Teardown, LCD Panel: passo 14, immagine 2 di 3 LG 25UM58-P Teardown, LCD Panel: passo 14, immagine 3 di 3
    • The LCD panel itself can be separated from the backlight.
    • Part number: BBSU1V 3467C2
  15. LG 25UM58-P Teardown, Conclusion: passo 15, immagine 1 di 1
    • A fairly tricky monitor to disassemble.
    • I'm 90% sure that removal of the LCD panel from the housing/frame will cause it to shatter (if it wasn't already damaged).
    • Replacement panels are about the same cost as replacing the entire monitor itself, making repairs unfeasible.
Rushil Kisoon
Membro da: 02/18/18
628 Reputazione
3 Guide realizzate
4 Commenti
Sorry to hear that happened. But it made for a really good teardown
Jacob Mehnert - Replica
I have 25UM57 internals are literally the same. same panel
Furkan Taşdelen - Replica
Hi, quick question. Do you know if that long skinny board on the bottom has the T Con board integrated into it? Or is that located on the main board centered on the back? Any info would be helpful as I believe I have a T Con issue with mine. Thanks so much!
Matt Coon - Replica
I quickly googled what the T-con is…
Do you know what specifically I should look for, maybe a chip? I’ll have a look through my unpublished pictures
Rushil Kisoon -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 121
Tutti i Tempi: 3,744
