Cosa ti serve
Unplug toaster from wall.
If toaster has been used, lay down paper towels or work outside to avoid making a mess.
Remove bread lifter/toast booster by prying it off. The plastic piece snaps over the metal part during assembly. Use a flat-blade screw driver from the side to widen the gap in the plastic clip while pulling the plastic handle out. Done right the handle can later be reassembled securely.
