Questo smontaggio non è una guida di riparazione. Per riparare il tuo HP Pavilion, usa il nostro manuale di assistenza.
    • Turn off computer.
    • Unplug from wall.
    • Remove wire from power source.
    • Turn off monitors, printers, and anything else that is plugged into PC. Remove all peripherals (wires) that are plugged into the back of PC and set aside.
    • Remove screws holding PC Door in place. Slide door out, remove, and set aside
    • After door is removed you can now see and have access to most components.
    • First Remove front cover by pulling plastic clips outward with screwdriver. After all 3 clips are removed you can remove front cover.
    • Remove front mounted perhipials.
    • Unscrew front mounted perhipials.
    • Unclip front mounted perhipials.
    • Remove cage for Personal Media Drive and HDD #1. Remove rear Data Cable by pushing in sides with fingers or screwdriver.
    • Unscrew with flat head screwdriver.
  1. Spedizione gratuita per tutti gli ordini superiori a 100 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
    • Lay PC on its side, Locate release tab on cage, press tab with long screwdriver, and remove cage.
    • Remove cage for Personal Media Drive and HDD #1. After releasing tab you can pull cage up and out. Remove power and data cables from HDD.
    • Remove 4 Screws with flat head screwdriver.
    • Slide HDD out of cage
    • Slide new HDD into cage Replace 4 Screws with flat head screwdriver.
    • With HDD Drive removed you now have access to the 4 slots of RAM
    • Remove RAM one and a time. Push top tab, then button tab, and slide RAM out of slot
    • Set RAM in order of removal so that it can be replaced in the same order.
    • Replace RAM in same manner as removal. Gently place bottom of RAM in slot and press in until you hear it click in place.
    • Move on to replace HDD
    • Re-connect power wire and data cable to HDD
    • Slide HDD Cage back into place until locking tab clicks
    • Replace screws and tighten down
    • Re-insert data cable and push in until it clicks
    • HDD installation is finished!!
    • Move forward to completely put back together PC.
    • Connect front peripherals to case
    • Screw on 2 screws to for aux/headphone jack/usb mount
    • Run wires through plastic clip and secure
    • Push plastic housing back onto mounting area to re-attach on/off button
    • Reinstall Front and sides of case Re-insert front off case and push in until it clicks Slide door back on and screw shut
    • Plug in all wires for: monitor, mouse, keyboard, speakers, etc..
    • Connect power wire to powersource and plug into wall
    • TURN ON PC !!!!!! Your now finished and ready to use your PC with new HDD and RAM
Madison
Membro da: 23/04/2018
491 Reputazione
1 Guida realizzata
Cadê fotos e tradução para Português-Br
edilson patricio - Replica
Noot HP Pavilion Desmonte e Monte
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 16
Tutti i Tempi: 357
