Introduzione
A look inside the Google Pixel Buds 2
Cosa ti serve
Features:
Sweat and Water Resistant
Bluetooth® 5.0
Spatial vent for in-ear pressure reduction and spatial awareness
Dual beamforming microphones / Voice detecting accelerometer
Up to 5 hours of listening time and up to 2.5 hours of talk time
Capacitive touch sensors / Dual IR proximity sensors
Back View of the Buds
Spatial Vent
Connectors for Charging the Battery when in the carrier / charging case
IR Detector for detecting when the buds are in the charging case or in the ear
IR Detector for detecting when the bud is in the ear
Grounded Metal Grid sound chamber cover
Closeup view of the Grounded Metal Grid
Since the Google Pixel Buds are made of plastic and are glued together, the only way in was to cut into the Google Pixel Bud. This is a destructive teardown
Once in, we are able to get our first look at the Google Pixel Bud's electronics. The stack up the Google Pixel Bud is as follows:
Touch Sensor
Main Circuit board
Battery
Speaker
Microphones
Charging and in Ear IR Detectors (not shown)
View of the electronics when removed from the Google Pixel Bud Enclosure
Flex PCB based Touch Sensor
Main PCB. Contains MCU, Bluetooth Radio, Audio Processing, Power Management, and Sensors
Battery
MEMS Microphones
Speaker Coil, Speaker Magnet, and Speak Diaphragm.
Grounded metal grid sound channel cover
IR Detector for in ear detections
Closeup view of the bottom side of the Main PCB
Unknown component. Labelled "ix6". Please leave a comment if you happen to know this component
Programming Interface and test points. Looks to be the standard ARM 20 Pin connector layout.
Bluetooth Antenna. Runs around the outside of the Main PCB - Top and Bottom
Closeup view of some of the components on the bottom side of the Main PCB
Closeup view of the top side of the Main PCB
Unknown Device - +7048/A5A59AB - May be the Accelerometer and Gyroscope used for voice detection. Please leave a comment if you know this device
Unknown Device - T 9 51 - Could be Flash Memory or RAM. Please leave a comment if you know this device
Unknown Device - SR 009 - Could be Flash Memory or RAM. Please leave a comment if you know this deviceNew line.
Closeup view some the components on the top side of the Main PCB
Unknown Device - +7048/A5A59AB - May be the Accelerometer and Gyroscope for voice detection. Please leave a comment if you know this device
25 Commenti
Great teardown, I can see the effort and finesse that it took., Great job.
Bru this is iFixit
I would also like to see teardown of the case.
