Introduzione
Full teardown of a cordless phone and accessories from 2001.
Cosa ti serve
This is a teardown of a GE 27990G3 cordless phone system from 2001. Sadly, while it still works, its 2.4 GHz wireless transmitter interferes with WiFi.
Whoever designed the wireless module really didn't want anyone to know what was inside. The very thick EMI shield is soldered, crimped, and epoxied on.
The shield took about 20 minutes to remove with diagonal cutters, 2 pairs of pliers, and 3 metal spudgers.
Needless to say, the shield is irreversibly damaged and the wireless module will probably never work again.
Components inside the wireless module:
Toshiba TB31261AF cordless telephone RF chip
Ceramic resonators
Unidentified square ceramic components with 2 cylindrical holes in them horizontally (anyone who has an idea what they are, please comment.)
The back of the board says that it was manufactured on August 29, 2001, making the phone 14 years old at the time of writing.
Interestingly, the Toshiba TB31261AF is designed for a 900MHz cordless telephone, but this is a 2.4GHz model.
Repairability score: 6/10
Phone is held together with only phillips screws.
Battery, the most likely part to fail, is a standard component and is easily replaceable.
Case is difficult to open.
Wireless module is very hard to replace and impossible to repair.
All wires (except for the battery) are soldered to the circuit board instead of using connectors.
Components on the main board:
4 MHz crystal
Variable capacitor
Small audio transformer
Miniature fuse
Varistor for surge protection
This board was manufactured on September 3, 2001.
Repairability Score: 4/10
Secondary base station is assembled with only phillips screws.
Circuit boards use mainly through-hole parts, so repair of individual components is easier.
Case requires lots of spudgering to open.
Removing the board requires a long screwdriver.
All wires and ribbon cables are soldered to the board and reinforced with hot glue.
In order to remove the board from the bottom case, you have to carefully reach in and free each one of the plastic pieces attached to the board from a clip on the bottom case.
All of the cables to the main board can now be cut and the wireless module can be cut off of the main board.
So what is inside the mysterious metal box?
Samsung K9F4008W0A-TCB0 512x8 Kb (512 KB) flash memory (designed for digital audio recording)
Crystal oscillator, covered in the same unusual substance found on the main board.
Unknown IC D16529CAC11CQC. Googling it turns up nothing that makes any sense.
This board is probably where the messages are stored.
Repairability Score: 3/10
Base station is only held together with phillips screws.
Removing the top circuit board is difficult because the buttons are attached to the top case with clips.
Opening the case requires 2 metal spudgers and a lot of force.
Removing the bottom circuit board is difficult because the case is still attached with soldered ribbon cables.
Overall repairability score: 5/10
The handset battery, the most likely part to fail, is a standard component and is easily replaceable.
Entire phone is held together with phillips screws
Cases are difficult to open and require heavy spudgering.
Most parts were not designed to be repaired.
