Salta al contenuto principale
Cosa ti serve
Questo smontaggio non è una guida di riparazione. Per riparare il tuo Franklin MWD-460A, usa il nostro manuale di assistenza.
  1. Franklin MWD-460A Teardown, Fully Assembled: passo 1, immagine 1 di 2 Franklin MWD-460A Teardown, Fully Assembled: passo 1, immagine 2 di 2
    • Here is the fully assembled Franklin MWD-460A Electronic Dictionary.
  2. Franklin MWD-460A Teardown, Battery Compartment: passo 2, immagine 1 di 3 Franklin MWD-460A Teardown, Battery Compartment: passo 2, immagine 2 di 3 Franklin MWD-460A Teardown, Battery Compartment: passo 2, immagine 3 di 3
    • On the back of the case, locate the battery compartment, its cover, two grooves, and the tab (which locks the cover in place).
    • Release the cover by pulling down on the tab with a fingernail.
    • While holding the tab down, insert the opening tool into one of the grooves and gently pry the cover off.
  3. Franklin MWD-460A Teardown, Separating the Panels Part 1: passo 3, immagine 1 di 3 Franklin MWD-460A Teardown, Separating the Panels Part 1: passo 3, immagine 2 di 3 Franklin MWD-460A Teardown, Separating the Panels Part 1: passo 3, immagine 3 di 3
    • Locate the battery grooves.
    • Remove the batteries by inserting the prying tool into the grooves (sliding it underneath the batteries).
    • Locate the one screw inside the battery compartment, loosen it, and remove it.
  4. Franklin MWD-460A Teardown, Separating the Panels Part 2: passo 4, immagine 1 di 3 Franklin MWD-460A Teardown, Separating the Panels Part 2: passo 4, immagine 2 di 3 Franklin MWD-460A Teardown, Separating the Panels Part 2: passo 4, immagine 3 di 3
    • Locate the six tabs holding the two panels together along the sides.
    • Insert the prying tool into each of the six grooves and gently separate each tab from its insert on the other panel.
    • Finally, separate the panels from one another.
  5. Franklin MWD-460A Teardown, Circuit Boards and Keypads Part 1: passo 5, immagine 1 di 3 Franklin MWD-460A Teardown, Circuit Boards and Keypads Part 1: passo 5, immagine 2 di 3 Franklin MWD-460A Teardown, Circuit Boards and Keypads Part 1: passo 5, immagine 3 di 3
    • Locate the three screws holding the upper circuit board in place.
    • Loosen and remove the three screws.
    • The screw in the top right corner is also holding a tab in place so remember where it goes.
  6. Franklin MWD-460A Teardown, Circuit Boards and Keypads Part 1 Continued: passo 6, immagine 1 di 1
    • Gently lift the upper circuit board to locate the up/down keypad and remove it.
    • Be careful when moving the upper circuit board as it's attached to the LCD screen and the lower circuit board.
  7. Franklin MWD-460A Teardown, Circuit Boards and Keypads Part 2: passo 7, immagine 1 di 1
    • Locate the eight screws holding the lower circuit board in place.
    • Gently pull up on the tape to expose the eighth screw.
    • Loosen and remove the eight screws along with their washers.
  8. Franklin MWD-460A Teardown, Circuit Boards and Keypads Part 3: passo 8, immagine 1 di 2 Franklin MWD-460A Teardown, Circuit Boards and Keypads Part 3: passo 8, immagine 2 di 2
    • Gently lift the two circuit boards (along with the attached LCD screen) away from their case.
    • Now peel the lower keypad from its case.
  9. Franklin MWD-460A Teardown, Full View of Disassembly: passo 9, immagine 1 di 1
    • Here is a full view of the disassembled Franklin MWD-460A Electronic Dictionary.
Chris L
Membro da: 12/17/14
1.522 Reputazione
3 Guide realizzate
Un commento
How can I fix the screen? The letters are so faded. :(
Paola Paniagua - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 12
Tutti i Tempi: 1,168
