Salta al contenuto principale
Cosa ti serve
Questo smontaggio non è una guida di riparazione. Per riparare il tuo Fitbit Charge HR, usa il nostro manuale di assistenza.
  1. Fitbit Charge HR Teardown, Remove Screws: passo 1, immagine 1 di 1
    • Take the 4 Screws out of the Sides you will need a T3 star Screw Driver
  2. Fitbit Charge HR Teardown: passo 2, immagine 1 di 2 Fitbit Charge HR Teardown: passo 2, immagine 2 di 2
    • You Pry out the Main board you can see the Metal Hooks
  3. Fitbit Charge HR Teardown: passo 3, immagine 1 di 1
    • You can Then pull out the Screws from around the Screen
Bradley Nelson
Membro da: 03/08/16
56 Reputazione
1 Guida realizzata
8 Commenti
Can the battery be replaced?
Rick - Replica
Mine was just over a year old (barely out of warranty) when it died. The Fitbit folks were kind enough to replace it anyway once I expressed my displeasure. I'd haggle with them a bit before going the DIY route but I'm definitely keeping my old one for spare parts. Hopefully someone will point out an aftermarket battery source before I need to do that.
fragmasterflash - Replica
The screws in mine were Torx T-2, not T-3.
Jake McIvor - Replica
The button is stuck in my ChargeHR. I bought the T3 screwdriver and it is too big. Either the screws are T2 or my screwdriver is too much imprecise.
Anyone fixed a stuck button?
Anderson Maciel - Replica
it definitely not T3 must be T2
Marc Frederick - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 16
Tutti i Tempi: 23,963
