Questo smontaggio non è una guida di riparazione. Per riparare il tuo Miscellaneous Electronics, usa il nostro manuale di assistenza.
  1. The Emerson Research SmartSet alarm clock automatically sets the time through the power of black magic and voodoo when plugged in. That pale blue display, while calming during the day, while be so bright as to make it nearly impossible to sleep at night.
    • The Emerson Research SmartSet alarm clock automatically sets the time through the power of black magic and voodoo when plugged in.
    • That pale blue display, while calming during the day, while be so bright as to make it nearly impossible to sleep at night.
    • That said, let’s tear it apart.
  2. Remove 5/16” screw and slide out battery tray. Remove four 1” screws. Note the address on the ID sticker. Maybe send them a Christmas card and see if they send one back.
    • Remove 5/16” screw and slide out battery tray.
    • Remove four 1” screws.
    • Note the address on the ID sticker. Maybe send them a Christmas card and see if they send one back.
  3. There is a ribbon and three wires connecting lid to bottom shell.
    • There is a ribbon and three wires connecting lid to bottom shell.
    • Carefully, pulling from front to rear, pull away lid from bottom shell and display cover.
    • Mark this ribbon as top. Or not. You know your powers of memory better than me.
    • Grip ribbon connector by corners (not wires) and pull straight back away from board connector.
  4. The speaker and chime wires are soldered to the board. Gently lay lid flat. Imagine it’s a sandwich you don’t want to upset Remove two 5/16” screws and two speaker brackets.
    • The speaker and chime wires are soldered to the board.
    • Gently lay lid flat. Imagine it’s a sandwich you don’t want to upset
    • Remove two 5/16” screws and two speaker brackets.
    • Remove four 5/16” screws from board.
    • Remove two more 5/16” screws from board.
    • Remove the board. Appreciate how easy everything’s been so far.
  5. This is the hardest part of the teardown. Take a shot. Meditate. Prepare. Carefully heat the glue along the plastic frame of the speaker. It will be difficult to heat the glue without deforming the plastic frame, as gratuitous amounts of glue were used and the frame wilts at the mere suggestion of heat. For those of you who can shoot fine lasers from your eyes, this would be a fine time to utilize that skill. Pull the speaker away. If you’re patient, you might be able to pull out the speaker without damaging the frame too badly. If patience eludes you, as soon as you apply heat, get something to use as a wedge, start prying, and pray for the best.
    • This is the hardest part of the teardown. Take a shot. Meditate. Prepare.
    • Carefully heat the glue along the plastic frame of the speaker. It will be difficult to heat the glue without deforming the plastic frame, as gratuitous amounts of glue were used and the frame wilts at the mere suggestion of heat. For those of you who can shoot fine lasers from your eyes, this would be a fine time to utilize that skill.
    • Pull the speaker away. If you’re patient, you might be able to pull out the speaker without damaging the frame too badly. If patience eludes you, as soon as you apply heat, get something to use as a wedge, start prying, and pray for the best.
    • Carefully heat and remove chime. This is much easier to remove than the speaker.
  6. Once you pull away the Sleep/Snooze buttons away from lid, the lid is disassembled.
    • Once you pull away the Sleep/Snooze buttons away from lid, the lid is disassembled.
    • Congratulations. Hard part over.
  7. Moving on to the bottom shell.... Mark ribbons, if desired. Left/Right, Tim/Tom—your choice.
    • Moving on to the bottom shell....
    • Mark ribbons, if desired. Left/Right, Tim/Tom—your choice.
    • Remove two ribbon connectors from board. Grip each ribbon connector by corners (not wires) and pull straight up and away from board connector.
  8. Spedizione gratuita per tutti gli ordini superiori a 100,00 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  9. Remove two 9/16” screws from power source. Remove power source from bottom shell.
    • Remove two 9/16” screws from power source.
    • Remove power source from bottom shell.
  10. Remove three selector switches. They pull off easily. Note their locations. Or play Tetris later figuring out where they go. Remove three selector switches. They pull off easily. Note their locations. Or play Tetris later figuring out where they go.
    • Remove three selector switches. They pull off easily. Note their locations. Or play Tetris later figuring out where they go.
  11. Remove one selector switch... ...and two thumb knobs.
    • Remove one selector switch...
    • ...and two thumb knobs.
  12. Remove three 5/16” screws... ...and two more 5/16” screws.
    • Remove three 5/16” screws...
    • ...and two more 5/16” screws.
    • (I know you just removed those two thumb screws and switch shown in the picture. We all make mistakes. Deal with it.)
  13. Don’t lift the board yet: there’s still a wire connected to the battery tray connector. Rotate board so that two screws securing the display board are accessible.
    • Don’t lift the board yet: there’s still a wire connected to the battery tray connector.
    • Rotate board so that two screws securing the display board are accessible.
    • Remove two 3/8” screws.
  14. Slide main board and display board forward to access battery tray connector. Remove 5/16” screw.
    • Slide main board and display board forward to access battery tray connector.
    • Remove 5/16” screw.
    • Remove battery tray connector by pulling the connector away from the bottom shell.
  15. Pull display cover and display board away from bottom shell and set aside.
    • Pull display cover and display board away from bottom shell and set aside.
  16. Very carefully heat the bracket securing the radio frequency indicator LED assembly. You will likely not be able to do this without breaking it. Pull out radio frequency indicator LED assembly.
    • Very carefully heat the bracket securing the radio frequency indicator LED assembly. You will likely not be able to do this without breaking it.
    • Pull out radio frequency indicator LED assembly.
    • Separate main board from the bottom shell.
  17. Back to the display.... Pull away the reflective shield.
    • Back to the display....
    • Pull away the reflective shield.
  18. Remove two 5/16” screws. and two more 5/16” screws. Separate the display cover from the display board.
    • Remove two 5/16” screws.
    • and two more 5/16” screws.
    • Separate the display cover from the display board.
  19. Separate the display cover from the display board.
  20. You’re done. Drink a beer. (Or, if you have access to it, a tall glass of horchata.)
    • You’re done. Drink a beer. (Or, if you have access to it, a tall glass of horchata.)
gjsmithemail
Membro da: 05/10/2011
131 Reputazione
1 Guida realizzata
Hi
I have emerson smart clock cks3528.by mistake I plugged into 220v.now it's not working. Can it be repaired?Pl help.
Email walkerjohn467@gmail.com
Jayashree - Replica
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 28
Tutti i Tempi: 4,736
