Introduzione
Due to an unfortunate incident with a microwave (the details of which will only be released upon the occasion of my demise), my Ember Mug met an untimely end.
As such, I decided to put to rest the questions that have come up on the forums regarding how to open the mug, what kind of battery it takes, and how to replace the battery.
I called this a destructive teardown because I was unable to find a way to remove the base with any combination of grasping and twisting, so I resorted to jamming a screwdriver into the damaged portion and simply prying the base apart using brute force.
This resulted in tearing off a flex cable that connected the base to the mug, so that is something to be aware of when opening your own mug. Along the way we'll investigate to see if there is an actual method that can be used to open the mug non-destructively.
Cosa ti serve
With a burnt spot on the bottom that gave my pipe wrench a place to anchor, I tried opening it using the wrench.
No luck at all; it simply would not turn left or right in any amount whatsoever regardless of how much muscle I put into it.
With no success whatsoever using the pipe wrench, it was time to go barbarian on the mug.
Jammed a screwdriver into the existing weakened burnt spot and made myself a pry hole.
After much grunting and cursing, the bottom piece finally gave way.
So here we see the hooks that hold the base in place, marked with red arrows.
Obviously it would only take a very small degree of turning to get the clips to release.
I am suspicious of this little finger pointed out in green. Due to the condition of my mug, I am unable to tell if this is a locking mechanism or just some sort of guide pin.
I've positioned the broken flex cable approximately where it should be on the mug's bottom assembly.
As you can see, there's very little room to maneuver, meaning it's going to be really easy to break that cable like I did when you open the mug.
Four 7.5 mm Torx T6 screws secure the circuit board/ battery assembly to the base.
Remove the shield.
Were the ribbon cable intact, this is where it would be connected at this point.
Here's what it looks like when it's unplugged.
I taped the connector onto the broken end of the cable to show you what it should look like.
Here we get our first good look at the battery itself. Given the shape and size, I'm guessing two 18650 batteries wired together with a BMS, but we'll see.
At this point these two components should just lift out; in my case they had to be pried out due to heat damage.
Likewise, the battery should be free now, but mine was fused to the circuit board.
Here we see the contacts for the copper rings on the bottom that transfer power to the mug.
You can see the pin that activates the button on the bottom of the circuit board.
Right about now you should be unplugging the battery from the circuit board. Unfortunately on mine the socket is melted to the connector so they cannot be separated.
I was forced to tear the connector off the circuit board to separate them. You can see here where it goes.
Here's what we find after removing the plastic jacket. Yep, as we figured, a couple of 18650's!
As if we needed any more proof, it's spelled out right there on the battery itself.
Here we see the BMS connectors on the ends of the battery. These batteries are connected in series; here we see one positive and one negative lead going to the BMS.
And here is the other end where the two batteries are connected together to make a series circuit. It's also fed back to the BMS for charging purposes so each battery can be charged separately.
Let's see what else we can take apart, shall we?
The rubber seal that keeps water out of the mug and coincidently makes it very difficult to open the mug just lifts right out.
Finally, the insulation material over the heating element also just lifts out.
I have to note that had I not torn the ribbon cable, the mug itself would have been salvageable assuming a replacement bottom could be obtained, but as it is, there's really nothing that can be saved on this mug.
Like my daddy used to tell me, if you can't serve as a good example, then generally you can be held up as a bad example!
15 Commenti
Great documenting. I too did a teardown and have made a replacement bottom from my 3D printer. You are welcome to the STL file. I printed one from PETG filament that matches with the hold down tabs.
Very cool; I haven't gotten into 3D printing yet, but have been watching the industry as it evolves with some fascination.
If you want to share your file with the community, you can go to the Edit tab of the device page and add it as a document; that would be cool to have available for everyone.
Have you uploaded the STL to any of the online repositories? I am extremely interested in getting my hands on a new bottom.
Max -
I'm curious how you handled the metal contact rings on the base. Are you planning on reusing the originals or do you have something else in mind?
